89 lx
I had one of my rear tires lock up and have had my car on jack stands for 2 weeks now trying to fix it. I read the shop manual, the haynes manual and searched this site for "drum" and read all those posts
I have 8 new shoes and 4 new drums (from 2 stores), and none of the new drums will fit over the new pads. The OLD drum will fit over the new pads, so I'm considering using it, since I'm at my wit's end
I turned the adjusting screw all the way in (shorter), and replaced all the springs and the wave washer.
I did blow out the piston, because I'm an idiot and hit the brakes. It was having this non-fitting problem before I did that however.
If I put the lug nuts on, I can crank the drum down onto the shoes, but the wheel obviously won't turn. The drums are dragging in the middle at "9 and 3", but slip easily over the top or bottom (crooked, obviously)
The pads look identical to the ones I'm taking off, and are pretty much identical to each other. I've tried a number of different combinations, but nothing seems to work
I can't think of anything that could be wrong at this point. I measured the new drums, and they're just over 200 mm or so, and the old one is 201.
HELP!
