how do you get the idiot rear motor mount out? I tried jacking up the transmission and the engine every way possible and it won't lift off the stud for anything. I know you take the nut off the stud,then are supposed to lift the engine to clear it,but it won't clear. do you have to take the dog bone off first? I know the mount is shot,because the bolt hole wouldn't line up properly for the dog bone,also the transmission is sitting improperly on the lower mount. all the motor mounts are new,even the lower one,except for the back. AUGGGGHHH. to put in my new dog bone yesterday,I had to attach a comealong to the engine side mounting bracket and pull the engine forward until the bolt hole lined up. I was twenty feet from the nearest tree so I had to stretch rope across the yard.
