the sensor i have came with a brass fitting adapter but it is too big for the original port... the sensor and the fitting both. so my idea was the same one that new accord driver had and that is to attach the brass fitting adapter to a piece of pipe (weld it in) then attach the sensor into that. however, my only question is which hose (radiator hose) should i splice this pipe into... the upper or the lower? or does it matter?
i realize that brass does not weld well so i will be replacing the brass with a steel one... but i'm just wondering which hose is the intake? i imagine it is the upper.
