http://cgi.ebay.ca/Upper-CONTROL-ARM...ayphotohosting
Does anyone know how hard it would be to put this together?
Using Honda parts it is easy. As long as everything in their kit is sized properly it shouldn't be bad at all.
Mike
i mean will i need any special tools or is it just in and tighten or will i need a press and some other specialty tools.
No special tools are required.
Mike
so it doesnt need to be pressed right.
i changed mine out and it took like ten min nothing should need to be pressed i installed adjustable one but the factory ones should be easyer to intall
I do almost all my work own work and what i cant handle i help to do it
be sure to grease (real well) the area inside the control arm before you install the bushing. should slide right in.
thanks alot guys, now im just waiting to see whether another user on the board will sell me his and im set. Thanks
