i know this is a noob question but how do u check for vacume leakes in a 1989 LX?
I am selling a combation swich PM me if u are intersted
Basicly i ride a bone stock 89 Lx sex machine that could use a little T.L.C. Rep that S***!
get carb cleaner or wd40 and spray it around the carb and the vaccum lines and if it bogs down or the idle changes then you have a leak.
ive sprayed carb cleaner in the car and it nearly stalls unless i stop spraying it and some 1 hits the gas so now where do i look next?
Originally Posted by FORFREE
where ever you sprayed the carb cleaner and it maid the car idle down, that is where the leak is. Use the little straw that comes with the carb cleaner to help you pinpoint the leak.
i sprayed it down the main barel
LMAO, thats why its bogging down. Don't spray it down the barrel, spray it around the vacuum hoses outside the carb.
oh woops lol ill do that lata
You want to avoid spraying it down the carb or spraying too much or too wide that the carb could suck the cleaner in inadvertantly. Spray in small spurts in a small area and listen for the change in idle.
another way to check for vacuum line vacuum leaks is by pinching the rubber vacuum lines with needle nose pliers... careful though cause old vaccum linesmay be damaged from doing this.
First off though get a vacuum gauge to see how much vaccum you are pulling. It may also be able to tell you if something is wrong with your engine internally.
https://www.3geez.com/forum/showthread.php?t=48569
that is the vacuum gauge help thread.
Just get a weber or do EFI.
You got about 20 foot of vacuum line on this car son & thermovalves that dip in the pocket book. But yeah, vacuum gauge is the way to go. DO read up on carb threads man, cause these carbs aint no joke.
