Results 1 to 4 of 4
Thread: Carbed Short Ram Intake?
    MIK3's Avatar
    Jan 2003
    1988 Accord DX
    Phoenix, AZ
    Is there even a point to this, I mean, does it help deliver air to the filter at all or no? I've only seen this once, so that's what brought up the curiosity...anyway, it looks like this. Not sure who's engine bay this is...but thanks for letting me borrow the pic.
    -Strugglebucket
    redaztec
    DAYUM!
    2ndGenGuy
    MessyHonda
    Re: Carbed Short Ram Intake?
    IMHO i think its as pointless as a ashtray on a motorbike, could spend the money on something like paint for the valve cover
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    that is the wrong way to do it.
    First off, you'll have to remove the filter inside the box.
    By removing the filter inside the box you do a few bad things.
    1) The PCV FILTER on the right side of the air box which now has a direct route to the carb.
    2) The hot air from the PRE-HEATER hose is now unfiltered when your car starts unless you disable the Hot Air Door Diaphragm.
    Also assuming you seal off any leaks between the filter and the carb you still have the huge PLENUM created by the AIR BOX body which is good for low end but will hinder higher rpm performance.
    You should really do a top flow filter and just use that on the carb.
    If you insist on short ram or cold air you can either do the cut air box mod or get a civic intake and use that for an adapter.
    Note that any air box modification or short ram adapted to the carb will alter the plenum and thus alter the vacuum signals. As it stands now the stock air box helps create more vacuum, with the air filter lid flipped or the box cut or a civic adapter added the amount of vacuum drops. Though I can see the civic adapter box giving more vaccum then an open filter on the carb.
    You carb and carb systems all use vacuum, so does part of you ignition. So you will proabably want to adjust your ignition and the carb to make full use of any short ram or air box mod you've done.
    LXi User Vector's Avatar
    88 Accord DX-RWD
    Kelowna BC
    i think cai is more effective than sri.
  1. carbed cold air intake
    By tay_ang in forum Carburetor Tech
    Last Post: 01-31-2006, 12:44 PM
  2. Carbed Prelude Intake Manny
    By HondaBoy in forum Carburetor Tech
    Last Post: 08-15-2003, 09:55 AM
  3. cold air intake vs short ram intake vs intake
    By 89accordboi in forum 3geez Accords
    Last Post: 11-28-2002, 11:10 PM
  4. cant get intake on carbed
    By 89accordboi in forum Performance
    Last Post: 11-23-2002, 09:05 AM
  5. cold air intake for carbed 3g
    By Mike's89AccordLX in forum Carburetor Tech
    Last Post: 08-24-2002, 11:35 AM
