I Have taken this from antoher thread.
Originally Posted by CASH24
I installed the legend rear suspension on my lx-i. I used the whole rear knuckles, rotors, calipers, and rear trailing arm. I just wanted to experiment and see if it would fit and to my suprise it worked after some custom work. Originally I just purchased the entire knuckles and tried to swap it in, but the bolts on the knuckles were spaced a little further then the LX-i trailing arm. So I went back to the J/Y and grab the trailing arms from the legend. The trailing arms from the legend didn't match up where it mounts to the body so I had to redrill the holes in the legend trailing arm (side that attaches to the body) and then I was able to mount it along with the knuckles. My stock Lx-i rims wouldn't mount because of the different lug pattern but I had 17" rims w/ a universal bolt pattern. The legend rear suspension raised the rear up a little, but I had GC coilovers so I just adjusted the rears and lowered to match the front. I never got around to matching the lug pattern of the front and rear (I wanted either all 4x100 or 4x114) because I was deployed to Iraq. When I got back I blew the tranny and had enough so I bought a GSR and sent the accord to the j/y. I know don't hate me for doing that. But I just wanted to share my experiences with the Legend rear suspension. Hope this helps you guys out and if not sorry for wasting your time.Originally Posted by guaynabo89
I have talked about swapping in the 88-89 rear suspension off a legend for years and was hoping someone would try it.
So other than where the trailing arm bolted to the body everything else matched up? Did you use the legend or accord strut? I was thinking if you used the legend srut that might have played into the car being higher. Maybe using the accord spring in the legend schocks might have brought it down also if the issue was the accord strut wouldnt fit right on the legend rear hub.
Anymore info you can remember?
Was the ebrake cable an issue?
I know the legend rear calipers use a pad that is almost twice as big as he sei or the civic/integra calipers. Plus the rotor is a little larger also with alot more pad surface area of course.Originally Posted by guaynabo89
Originally Posted by smufguy
Offtopic: The 1g Legend came with two dfferent Rear suspension designs. One was a coilover and the other is not.
Correct
the 86-87 Legned use a spring perch with shock mounted on the trailing arms while the 88-89 Lagends Use a rear strut assembly. The 88-89 Legend rear suspension is the one which almost mirrors the accord sei rear suspension. except of course without the bigger caliper and rotor combo.
I'm pretty sure you can swap out the caliper and rotor from the 88-89 Legend and slap it on an sei leaving us with bigger rear brakes.
The front calipers are the same as the 88-89 accords though and I think they might use a larger rotor though thna the Accord.Originally Posted by Legend_master
To correct you a little on the legend suspention some of the 88 models had the non coilover design and some did not. Also the non coilover design was only on the sedan, all the coups had coilovers designed suspention. The rear legend rotors are 10.2" or something and I agree that the calipers prob just bolt right on. I want to know what CASH24 used for bushings since he redrilled the controle arm and I am also curiose on what ebrake cable he used.
