Are these cam gears for B20A??? the company is based in Australia:
http://www.hpower.com.au/
ACCORD 3G RUNS FOR EVER
it says 1600 and 1800... pretty sure they mean B16 and B18 since they are vtec b20 would be 2000
Seems to me 1600 & 1800 are engines in CC displacement.
You can use the adjustable gears from the SOHC F series engines. You have to use 2 of them of course.
Thanks carotman for the info.
I just ask because this company has different part number for B20A cam gears than 1.6L and 1.8L engines so maybe is specific design for B20A.
Don't forget that Australia is the home of some jdm Accord 3G SI:
HP-MVDOH001-EVT Camshaft Drive Pulley
1600 DOHC Non VTEC
CIVIC/CRX
HP-MVDOH002-EVT Camshaft Drive Pulley
1600/1800 DOHC VTEC
DOHC 1800 Non VTEC
CRX/CIVIC& Integra
HP-MVDOH003-EVT Camshaft Drive Pulley
DOHC 2000cc B20A
Maybe you should put that in the FAQ or something jean, cause seems like I am the only one if not one of the very few, who knew about ur discovery on this matter like a year back.Originally Posted by carotman
A friend of mine purchased those gears to put on his B20A1 a while back but he couldnt get them working properly, he had to shave some material off of them where they attach to the camshaft and after that he couldnt get them to align like they should, but I never saw them being installed so I'm not sure if he just jacked up.. Has been keeping me back from buying those cam gears thoughOriginally Posted by carotman
Lok, the 3rd gen ludes also has the engine code B20A in the Asian country's and those engines has the same size cam gears as B16A engines.
Well, It was Rob that had made this discovery (so I give him credit for it)
I have 1 AEM camgear here (didn't get a second one yet) and compared it to the stock B20A and it was a perfect fit...
I will re-compare them soon and take pictures of everything.
Good call on this Praveen. I often forget to put stuff in the FAQ (shame on me)
The cam gear from the 90-93 accord will fit the B20a As Carotman said the adjustable gears from the SOHC F series engines
Whats a good make to get for the F series? Might have to get a pair for my Cat Cams Cams also anyone know what happened to my B20A camshaft post??? disappeared?
P.S. Makes that are popular so that i can order in U.K.!!
the following are kinda decent ones with the manufacturer and the part numbersOriginally Posted by rjudgey
Golden Eagle (GSC102-TB,GSC102-BT, GSC102-BB, GSC102-TT), AEM (23-803), Skunk2 (304-05-0230), Venom (VNM-C21-127S)
Yes yes yes, very much shame on youOriginally Posted by carotman
thanks which make so you think will be easiest to get in U.K. AEM??
AEM and Skunk2 should be readily available in UK.
I can get the Skunk2 for £115 pounds each and there in stock just to check it's a F20 Accord engine correct?? and do i need to do any mods to the pulleys to get them to fit or they just bolt straight on??
Thanks Rich.
well like carot i hate to take away from rob. whether he knew or not. Josh rosenbaugm told me when i bought his stuff in 03. Im not sure he found out or if mike lee told him. Versanik should have them on the car he go from josh
NO its the USDM F22 engine code. it has to be the SOHC USDM F22 engineOriginally Posted by rjudgey
thanks
well ordered them cost me $98 each for Prelude F22 which had the same pn as the F22 Accord total cost was $250 which is about £130 pounds U.K. dealer wanted £230!!!!! So saved £100!!!!! more money for other parts!!
Which ones did you order?
Skunk 2 i was told there the best?
I guess as long as they dont weigh a ton and the sprockets dont come loose they'll work fine, right
Lets just hope they fit!!
Knowing my luck JDM pulleys will be different to Euro ones!!
The rod small ends are so fingers crossed that there not different!! Suppose i could allways convert it to 3G prelude gears and run H23 timing belt!! But don't fancy changing that again at the moment last one took long emough!!
the f22 cam gears work fine on my (josh's) b20a.
bury the bach.
http://home.stny.rr.com/versanick/burythetach
