I think my clutch has seized up on the pressure plate. No matter how many times I press the pedal, the clutch still won't release and let me go into gear with the engine running. Didn't touch the transmission. All I did was engine performance work with engine still in the car. I did however flush it with water via the starter hole when I removed the starter to flush out all the clutch dust. I guess that was a bad thing to do. Clutch probably rusted into the pressure plate or the clutch release bearing seized up from rust.
My idea is to hold the clutch pedal down with a pipe or stick against the seat all the way forward then see if I can tap out the clutch/flywheel with a hammer and a big long screwdriver/prybar while spraying some brake cleaner in there. That or start the car in gear a few times, but that seems scary to break something. Anyone have any ideas what it might be? Or if it is what I said it is, what's the best way to remedy it? I know my clutch is fine, doesn't need to be replaced. I hope I can fix it without having to remove the tranny.
