firstly, see this thread so you understand why: https://www.3geez.com/forum/showthread.php?t=52936 very important
Ok, so what is going to happen on this car is there will be 4 front hubs, 2 left, 2 right. I will be using front hubs on the back, and therefore front brakes on the back aswell. The problem with this is that during the safety inspection im sure they will notice if it has an ebrake or not, and for it to be considered road legal, im 99% sure it needs a functional non-hydrolic e-brake.
And before you say we should just use the rear hubs and use the factory e-brake stuff, no that wont work. The only way I can drive the rear wheels is with the front hubs on the back.
Im wondering if SEI rear brake stuff will work on the front hub as for e-brake hardware, but that shit is hard enough to get ahold of up here in canada.
It can be custom by all means too, it doesnt have to be factory anything.
I was thinking some sort of C clamp around the outsides of the pads, ,and when you pull the lever itll do the same sort of thing as the regular ebrake, using cables to pull 2 parts of the c clamp together.
Im bashing my head into walls trying to figure it out, and its not helping.... I cant even visualize what I need right now because all the hardware isnt infront of me (stripping the car tomorrow after I pick up an engine lift).
PLEASE help me with this!
