Glass ( Fiberglass ) will burn out after a while then you have to repack it or buy a new muffler.
You wanted 210 HP... Say you make 180-200 HP
The hooker flows 441.... If you make 210 HP which you can make, you'll be flowing more then the hooker can handle AFTER you go past 200.
So where ever in your RPM range that you peak at 210 is the only place the muffler should show any resistance.
Let’s say you only get 210 hp at 6,800 rpm... well the rest of the time you are below that you should be fine.
200.4545454545 hp needs about 441 CFM of flow.
Or 441 CFM is good for 200 HP
You're not constantly flowing your peak CFM though, you don't have 200 HP at 2,000 RPM
So I said IF you plan to make over 200 HP then you might consider dual mufflers or finding a single chambered muffler that flows more.
You can find straight through mufflers that flow more but then you don't get any tuning advantages unless you use a straight thru as part of the pipe length. Which mean a 2" straight thru before the first real change in cross-sectional diameter or expansion into a greater volume, IE: the atmosphere or a large chamber.
No stepping up a diameter of the hooker does not always mean you'll gain any more CFM from the muffler. It’s usually the internals that are the restriction not the pipe itself. That’s why you first determine your pipe diameter. This pipe diameter is only after the first expansion/first change in cross-section to make sure your exhaust flows... this is not a part of header length or diameter. Now this doesn't mean you can't make more HP then what is shown, it simply says you'll be building backpressure as your HP exceeds the Max CFM of the exhaust system.
1.75" Single Exhaust pipe flows about 275 cfm good for 125 HP
2.00" Single Exhaust pipe flows about 361 cfm good for 164 HP
2.25" Single Exhaust pipe flows about 457 cfm good for 207 HP
2.50" Single Exhaust pipe flows about 564 cfm good for 256 HP
The Hooker I selected for you is 2.50" inlet and outlet
Why?
1) Because 2.50" is good for 256 hp
2) It is as close to 1" larger than 2" it forms a collector and an anti reversion dam when installed correctly over the 2" pipe.
While it does make sense on some level that the company would increase the flow of the internals to any increase in pipe inlet and outlet diameter... that is not always the case.
FyreDaug
Lets say this horrible sound is a 0 and stock is 10, where would you approx place that hooker?
Code:
Sound Quality Idle ( 10 Stock / 0 Crappy Can )
- 7 -
- 8 - With a good Resonator
Sound Quality WOT ( 10 Stock / 0 Crappy Can )
- 6 -
- 7 - With a good Resonator
Code:
Sound Volume Idle ( 10 Stock / 0 Loudest open pipe )
- 5 -
- 6 - With reducer after muffler 2.50" to 2.25"
Sound Volume WOT ( 10 Stock / 0 Loudest open pipe )
- 3 -
- 4 - With reducer after muffler 2.50" to 2.25"
I still say a Cat is Better then a Res, espicially one that flows well, If you do install a true Helmholtz resonator you'll only get so much from it. The Magnaflow Resonators are packed though they may have some angled linings inside the pipe to deflect sound waves back into the incoming sound waves. With a cat you'll disrupt the sound waves more. I have made exhaust systems before with no res but kept the cat, using your scale:
With Cat : 8 at idle and 6 at WOT for sound quality
No Cat : 7 at idle and 4 at WOT for sound quality
This is with a PT Muffler
