do not buy upper control arms from advance,they say TRW on the box,but they are made by the three five company not TRW. they are garbage. I was on my way to work,and my right wheel started shaking and pulling so hard to the right that I almost couldn't keep it on the road. I made it to the plant and discovered my right side ball joint on my upper arm was shot. it's only two years old!!! I had to bring my car home on a flatbed,then I discovered the left one is shot too, bought and installed at the same time., I could see one maby going bad that quick as a fluke,but both of them failing at the same time?![]()
the main problem with them is the boot is so poorly designed it has a seam right where it flexes. so of course it splits wide open in a short time,and bye bye grease and ball joint. I paid over a hundred bucks apiece for these arms plus the bushings which can't be removed without destroying them.
if there was an aftermarket boot available to replace the one on them they might be all right, but now i'm stuck with the same crap again under warranty. and the parts won't be in until friday.
