Results 1 to 4 of 4
Thread: A/C Blower Help
    LX User azazel_18_2's Avatar
    Feb 2005
    89 Accord LX-i
    Cushing, OK
    A/C Blower Help
    I have an 89 accord lxi with 125k miles on it. The a/c blower started smoking so I went to NAPA and got a new one. I installed it and it worked fine. Thenk my a/c compressor screwed up so I didn't used the blower for about a year. Now I got the a/c fixed and the a/c blower just barely pushes anything out of the vents. Can someone help me?
    Re: A/C Blower Help
    Im suspecting a leak maybe so water or junks gotten into the air box. Make sure the drain is not plugged. Mine plugs all the time if I park under trees and stuff. Next there might be a resistor involde with the fan speed possibly.
    Re: A/C Blower Help
    if it uses the air box to push it then most likely your blower motor is going out or the blower motot resistor is going out, i had no airflow at all, now that i put a new resisitor in it works great.
    Feb 2005
    89 Accord LX-i
    Cushing, OK
    Re: A/C Blower Help
    Where canm I get the resistor? What should I call it. I called Napa and they acted retarded.
  1. S.O.S. blower fan blow out?
    By firefighterwhite89 in forum 3geez Accords
    Last Post: 11-29-2011, 09:57 PM
  2. S.O.S. blower fan blow out?
    By firefighterwhite89 in forum EFI Tech
  3. Blower problem
    By LxAcc510 in forum 3geez Accords
    Last Post: 07-18-2008, 05:20 AM
  4. A/C Blower Not Cutting It!
    By Boltgunner in forum 2geez Accords
    Last Post: 07-25-2007, 06:57 PM
  5. Blower No Blow
    By skull1441 in forum 3geez Accords
    Last Post: 08-21-2004, 06:27 AM
