FyreDaug
Im just working on the assumption that the rest of the motor is good for up to 7500 and I wont spin bearings, and that the majority of the higher revving issues on this car is valve float, so correct me if im wrong.
Im gonna be picking up a stage 2 tri-flow cam for this kart project, and they claim 3500-7500rpm, and there may be a few times where id like to hit that high, 6000 is the most I really ever see out of these motors, its carb so I could technically go higher, but if it is a valve float issue above 6300 or so, then id like to get some tighter springs and some other minor head work to get 7500.
Is there any bottom end stuff needed? Are the main bearings good for that kinda speed?
