ok now to save flooding the forum with threads about my car playing up, i think ill just leave all the problems to 1 thread for now. so, here is the 1st problem to start us off.
1. is it my timing causing my car to run well above 2500 (mainly 3500) rpm? yesterday i retarded it, then it ran shitty as, so today advanced it 2 teeth and it runs alot better. it even idles now!!! yay!!! it idles at 900 rpm which is pretty good i supose but it has the most slowest response when flooring it between 900rpm and 2500 rpm, above that it runs fine. what could be the problem there?
2. so after looking at the manual, and my dad confusing the hell outta me, he leaves me lost in this timing thing. so theres a red mark down in the crank case a little bit away from the white TDC mark. and wen were setting the timing my dad wants to use the red pointer as the TDC point coz some reasons i wouldnt have a clue about. im lost with this, can someone explain how the timing is all set up?
3. yesterday, i just put $10 in the car, then it started, but now it doesnt run, hasnt even been running 20 minswould that be my rear fuel filter? i can just bypass it right? or can i just reuse the 1 from the other car?
