Results 1 to 7 of 7
Thread: Vibration
    89 SEI Honda Accord
    Attending college in SC but actually from the U.S. Virgin Islands
    Vibration
    I just installed the cold air filter this morning and now the car vibrates when I am going about 1500 rpms. It sounds kind of like it's revving itself. Please someone help me out and let me know what I should do.
    Canman. Reppin for the VI till the day I die.
    Jun 2001
    88 lxi coupe
    gainesville, fl
    okie this post should be at technical
    what did you meant by cold air filter?
    LX User 89accordlxi's Avatar
    see user name
    IA
    after any mod, you should always reset the ecu if you haven't already. Get the car warmed up, shut it off, unplug the ecu fuse under hood, wait 5-10 minutes, put fuse back in, start car without stepping on gas, let idle for 5 minutes or until radiator fans come on, turn car off and your set.
    i'm out..
    89 Lx-i
    Performance: K&N filter,custom CAI, Accel coil, MSD 6aL ignition, magnecor wires, high flow injectors, FPR, sport exhaust,Tokico springs/struts
    Appearance: white gauges, side markers, headlight conversion, clear bumper signal/fog light conversion, SE-i center armrest and cupholder, SE-i leather seats
    17" ADRs with 205/40/17 khumos
    future plans: 16" or 17" rims(can scratch that one off the list 9-12-02), headers-high flow cat.-cat back piping. Rear disc brakes from SE-i, reground cam.
    10/Honda/Ridgeline
    NJ
    he means the filter that he had in his freezer the night before.
    89 SEI Honda Accord
    sorry about that, i replaced my ignition coil and now it runs fine. I meant the tube that you buy to put on your throttle body that usually comes chrome with a filter at the end.
    1990 Honda Accord Ex 5spd.
    Knoxville, TN
    did you plug up the hoses that were connected to the side of your air box? cause those dont go any were now... and then i found that i have 2 hoses that i didn't reconnect. One seems not to be a vacuum or a blower.. and the other kills my car when i plug it up... 17 and 18 are the hose numbers.. what do they do?
    "If you were paying attention DANIEL you'd know the Nintendo's pass threw everything!"
    - Col Jack O'Neal - Stargate sg-1.
    LX User DanG86LX's Avatar
    Jun 2002
    86 Accord LX, carb, AT
    Edmonton, Alberta
    thread !!! :badass:
    Anyway, answering the last post:
    #17 is a air bleed line and it takes air from black air box.
    #18 in should NOT be plugged to air box! It comes from both "idle opener" and "fast idle unloader" and goes to a thermovalve into intake manifold (firewall side). It should have vacuum with engine warm.
    #8 line from airbox goes to intake manifold vacuum port (multiple Ts). This one might kill the engine if not plugged in.
    #15 goes to one of the bleed thermo-valves inside air box (some cars don't have this one).
    Hope that helps!
  1. Vibration
    By billyaccord in forum 3geez Accords
    Last Post: 09-27-2004, 07:55 PM
  2. Vibration and my Sub
    By MrBen in forum Interior & Exterior Care
    Last Post: 03-08-2004, 10:50 PM
  3. getting rid of vibration
    By 89cordlx in forum Interior & Exterior Care
    Last Post: 12-01-2003, 10:39 AM
  4. Vibration.... woo.
    By MrBen in forum 3geez Accords
    Last Post: 10-17-2003, 02:54 PM
  5. Very Bad Vibration
    By BigCook in forum 3geez Accords
    Last Post: 04-17-2003, 04:27 AM
