Results 1 to 11 of 11
Thread: Cooling fans not turning on automatically.
    LX User 1989accordaz's Avatar
    Apr 2004
    1989 Accord LX
    Tucson, Arizona.
    My 1989 AT is overheating, just yesterday, I notice that my fans are not coming on at all. The big one does when I turn the AC on, but not the small one. What could be causing this problem?
    It seems that all the mechanics on the area are booked until next week.
    Thanks in advance for any pointers.
    You are good...but I've seen better.
    1989 LX AT
    300,000
    Re: Cooling fans not turning on automatically.
    did you see it its plugged on correctly, or the fuse is out? or it might be that the small fan might be burnt out?
    LXi User 87lxiaccord's Avatar
    1987 honda accord
    st.pete
    yeah check if the wires have a short in them
    <3 sohc
    i had this problem and ended having to replace the fan timer unit (only on lxi) and also the radiator fan switch. but both fans would come on with the a/c so you might have a different problem
    in the meantime keep your eye on the temps.. my car would be ok as long as i didnt idle too long
    10/Honda/Ridgeline
    NJ
    unclip the lower rad thermo switch and jump the clip (wiring harness side) and see if the fans come on. Usually the Small fan is the condensor fan (turns on when the AC switch is pressed) and the big one is the main radiator fan. I have them both running in parallel and wired up to a switch near my shifter. Basically, once the needle starts moving, i just turn the switch on and the fan runs constantly, this is how i have been driving around for 3+ years.
    Apr 2004
    1989 Accord LX
    Tucson, Arizona.
    OK to start, uncliped the lower rad thermo switch and jumped the clip (wiring harness side) as suggested, and only the big fan turned on. So next, I removed the condensor fan ( small fan, driver's side ) and using 14 gauge wire, I connected the fan's plug straight to the battery since it runs on 12V...nothing, the fan is dead.
    So I am positive that the fan is FUBAR. Now, the autoparts has it for 125 bucks! I haven't bought it yet, the price kinda caught me off guard since the rad fan is only 45 bucks.
    Thanks everyone for the help so far, I'll keep you posted. I still think that my thermo switch is bad in addition to my bad fan
    1989 LX AT
    300,000
    you can get that at a junk yard...if you want more cooling you should put another big fan...from wut i heard they just plug in
    You could also do what TWOLOUDNPROUD did here's the post
    https://www.3geez.com/forum/showthrea...=radiator+fans
    Accord of the Year - 2008
    TWOLOUDNPROUD's Avatar
    May 2003
    Go aftermarket like i did its cheaper and they work better and more quiet to i did two 1100cfm fan and they keep my B20a nice and cool.I paid like 25.00 each fan on Ebay.
    10/Honda/Ridgeline
    NJ
    i got a Main radiator fan just chilling in my garage. YOu can do what Mike (A20A1) did and run two big fans (two main radiator) fans if you would like. Lemme know if you are interested.
    Apr 2004
    1989 Accord LX
    Tucson, Arizona.
    Well, just to close this thread, I replaced the fan ( bought it at the salvaged autoparts for 75 bucks) and I replaced the thermo switch becasue the fans were not turning on automatically. Now it's all good.
    Running two big fans would be nice, I just was not up to tweaking any thing else this weekend.
    Thanks all for the help.
    1989 LX AT
    300,000
  1. cooling fans on when car is off???
    By hootymo in forum 3geez Accords
    Last Post: 02-13-2024, 06:55 PM
  2. Cooling fan not turning on- I'm stumped!
    By sunofogun in forum 3geez Accords
    Last Post: 05-20-2007, 11:26 AM
  3. cooling fans
    By labeledsk8r in forum 3geez Accords
    Last Post: 07-06-2006, 09:00 PM
  4. Cooling fans not turning on, Missing plug on temp switch
    By Super_Blue_89LX in forum 3geez Accords
    Last Post: 09-28-2004, 10:58 AM
  5. Cooling Fans
    By HondaBoy in forum 3geez Accords
    Last Post: 11-30-2003, 10:56 PM
