Have a look here under Rods Eagle have some titanium rods listed for B18A/B for Integra non vtec are these the same ones were using on our A20 blocks with the 21mm modified piston pins from Diamond pistons??
http://www.importperformanceparts.net/
If so that price is seriously attractive in U.K titanium rods are like £1500 pounds a set custom made if this is right it will be half that cost!!!! And i can get forged pistons made by a company that use to be a Mahle factory in Argentina for £400 with the right size piston pin to fit. That will certainly help my little A20 and ET1 rev it's little socks off!!!
Oooh i'm getting all excited again.
Engine build with:
Forged pistons
Titanium Con Rods
Aluminium Flywheel
Clutchnet solid hub kevlar Disk and Red pressure plate
Big valve head with custom stainless steel 33mm inlet valves and 38mm exhaust valves
Custom inlet manifold with 6" runners
Twin Weber 45 DCOE's moddified with 100mm bellmouths
Custom Camshaft with 290 degree 11mm lift inlet 295 degree 12mm lift exhaust
Well Head is nearly done exhaust valves are awaiting to be turned, the gap infront of the inlet guides have been welded up, the exhuast ports have been moddified, the chambers flowed and polished, seats cut, valves profiled with my special finish, and then we have the inlet manifold with it's extra long 6" runners with tappered ends. Just waiting to see what the Camshaft guy reckons he can do with a re-profile on the original camshafts. Then need to build ablock that won't explode like a hand grenade being thrown into a bunker like the last engine did!!! This will be mental not sure whats going to win the B20A or the A20A it's going to be interesting year will post some pics on cardomain as soon as i get some. I reckon the B20A will just pip the A20A i reckoning on 230bhp for the A20A and 240-250 for the B20A we'll see all down to how my headwork designs go, might even bring the ET1 back to life still have one early ET block left although it needs a liner put in due to previous engine bowout damageing the bore badly. I really do like the ET1 head i still personally think it's the best 80's head that Honda designed.
