The power steering pump belt adjustment is possibly the most ghetto thing I've seen Honda design. I read the service manual and even did it that way, and I'm still thinking... Do you seriously have to pry up the pump to get the belt tight? That's ghetto. Anyways, no more squeeking, and power steering is working perfectly.
I need a couple relays for this thing. I was trying to figure out why the right front window will roll down (sometimes), but not roll up. There was also hesitation with the left front window... but it works more often then the right window. I checked the fuses (in case the current was jumping) and they are good. I took out the window relay and put it back in. While I was holding it I noticed it was warm. I felt the relay next to it, and it was cold. I think the window problem is the relay.
(Problem fixed... here's the thread: https://www.3geez.com/forum/showthread.php?p=737231)
Also, when I put my hazards on, sometimes only one side of the car will light up, so I need the hazards relay also.
My reverse lights don't come on, so I guess I need to replace the bulbs.
Other then that, the only thing that I'm not happy with is the fact that the car spews smoke (from oil) out of the exhaust, even when just idling. If anyone has a spare engine, I need one...
Also, if anyone has those relays, I need those too.
