Hi guy's need to pick your brains again!! Found some stainless steel valves from Toga for B20A5 are these the same as ours there only $11.99 each what i was thinking of doing was using the 33mm inlet valves and have them machined down to size to fit the exhaust seats from 33mm to 30mm stock is 28mm anyone tried this at all? I suppose worse case scenario i'll have to pull out some exhaust valves and measure up.
