Just thought I'd throw this out there since I had an experience with it today. Just so that it's here if anyone ever decides to use the search feature. As some of you know I've been working on my 1st gen odyssey, making it a little quicker, dressing up the engine bay, and upgrading the brakes. I decided to order one of the cheapie ground kits from ebay. They make all kinds of crazy claims like 8-10hp and what not, but I figured at the very least I might get a smoother idle.Here's the one I got. Well long story short I diconnected the battery, pulled all the old grounds and ran a ground wire to every ground location. There were 2 direct grounds from the battery to the chassis and 3-4 other locations where there were grounds from the chassis to a major component. After I reconnected the battery I turned the van key to the accessory position and all my stuff worked. I figured great, I'm good to go. Turned the key and one loud click then everything died. I was sweating bullets, I thought I screwed somthing up big time. I disconnected the battery, got my multimeter out and started checking all the ground connections. Turns out the damn kit is aluminum and coated with a gold paint. I just assumed it was a brushed copper/nickel type finish. The paint is NOT conductive. I had to pull the whole thing apart and took the metal dremel brush to every peice that made contact with the battery or another cable. Put it all back together, tested the ground again, connected the battery, and walla the van started right up and it actually does idle a tad smoother. It's hard to believe that they don't clean the contact area's of any paint before they ship these things, but I guess you get what you pay for. Perhaps mine just missed the cleaning or maybe this is how they prevent the contacts from corroding while they are stored I don't know. But I figure this will save the rest of you some headaches if you decide to do this later on.
