Results 1 to 3 of 3
Thread: Need a cooling hose/pipe diagram....
    Question Need a cooling hose/pipe diagram....
    I just want to make sure I got everything correct, I have an 87 Carbed car and I need a diagram or something that shows the routing or the cooling hoses. If anyone has one please post it thats a lot.
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    Don't forget to use new carburetor base gaskets when removing the carb.
    There are two gaskets
    One is an O-Ring type gasket, the other is a sheet gasket.
    If it leaks coolant can make it way out of the hole in the intake manifold and get sucked into the engine.
    Re: Need a cooling hose/pipe diagram....
    The reason I ask is because my engine is taking a crazy long time to reach operating temperature. At first I thought I might have run a coolant line that was bypassing the thermostat or something. But your diagram shows everything is alright. Any ideas why its taking so long? Collant is topped off and I doubt any blocked passages as the engine was power washed and all passages were cleaned throughly. The temp sensor was carried over from my orignial engine and it functioned flawlessly. Ideas?
  1. preheater hose (aka "hot air pipe")
    By bongbang in forum 3geez Accords
    Last Post: 06-19-2009, 07:12 AM
  2. Need Vacuum Hose Diagram
    By acessence in forum Classic Honda Community Chat
    Last Post: 07-17-2005, 02:43 PM
  3. Disconnected pipe/hose.. Eh?
    By Acid X in forum 3geez Accords
    Last Post: 07-06-2005, 10:32 PM
  4. true flex pipe VS. Socket joint pipe
    By Ace in forum Performance
    Last Post: 04-27-2005, 07:53 PM
  5. Vacuum hose diagram, for putting hoses back on
    By Zend in forum Carburetor Tech
    Last Post: 02-06-2005, 01:11 PM
