Ok guys, time to help me troubleshoot this issue:
My car has an MSD 6A ignition, and MSD blaster SS coil. I have an 8.5mm MSD plug wire going from my coil to my cap. I am using some 7mm accell loaner plug wires my neighbor had on his mustang from the cap to each spark plug.
This exact setup has ran perfectly fine in the past, with no apparent issues.
When I try to start the car, with the timing light on the #1 plug wire, I am getting NO spark to it. In fact I am not getting any spark out of the cap. My coil is definetly cranking out spark, if I pull the plug wire off it will arc to the body, so I know the coil is working.
Also if I take the plug wire and install it into the coil, and leave the end that is SUPPOSED to go to the cap free, it will still arc around and ground out... So I know the MSD wire is not faulty. Also, we put the timing light on this wire when trying to start, and we did get the gun to flash at us.
Another strange thing is that from the time I start cranking the car over, to the time the wires will arc out to ground seems to be significantly delayed, like over a second. I WAS thinking maybe it just needed enough voltage available to make a much bigger arc than it would normally need to throw a spark. However when I have the timing light on the coil to cap wire, it takes almost a second of cranking on the key before I see any flashes from the timing light.
Now I cannot explain the wierd lag issue, but the spark not getting out of the cap to each plug wire 'seems' like it would be a plug wire problem, or possibly a problem with the cap and/or rotor. The cap and rotor are new from when I put my motor back together, and the plug wires are the same as before too. So nothing has really changed at all.
I haven't pulled the cap to inspect the rotor yet, but I am willing to bet it is FINE. The whole system worked great when I pulled the motor apart, all I did is yank the dizzy right out of the head before I pulled the head, and the dizzy just hung out for a few weeks until I got it all back together. I never had the cap off to tweak at anything, so it seems unlikely to me that the cap/rotor/wires are truely the issue.
Now, there are a few things I have changed since the last time the motor was together and trying to run, maybe you guys have an idea if any of this could have an effect on how it might run...
I rewired an 86-87 style TPS plug onto my 88-89 TPS (I have an 89, but I am using an aftermarket throttle body that needs an 88-89 style TPS). Also I removed a bunch of shit from my mystery vaccum box. Mainly the EGR valve, and AC idle boost valve.
I plugged in my old friend the IACV since I figure I will need all the help I can get, making this car idle.
I had to rewire one of my engine coolant temperature sensors, because the wires broke on mine (could backwards wires cause this bizzare issue??)
Now I am assuming there isn't any vaccum lines on the car that could affect the ignition system, but I did pretty much redo all of my vaccum lines because of the intake manifold I am using.
So I am definetly at a loss for why I am getting spark to, but not out of the cap, and why the hell the spark seems to be delayed.
Any ideas?
