Page 11 of 31 FirstFirst ... 78910111213141521 ... LastLast
Results 251 to 275 of 754
Thread: My wrecked 89 Hatch (pictures)! 56k no!
  1. #251
    Idaho
    Re: My wrecked 89 Hatch (pictures)! 56k no!
    yeah how much lonher untel we see some paint on that hotte
    At the rate I'm going...Maybe the end of summer.
  2. #252
    yay cant wait to see her
    what do u have left to do?
  3. #253
    Idaho
    Led tail lights, dents, headlight welded in, parts put on, wing sized to fit.
  4. #254
    cool LED tails cant wait to see your car Le Led Mobel drivin by MR L.E.D himeself
  5. #255
    Idaho
    Shit son, you don't even know, I've been working on my tail lights already.
  6. #256
    Idaho
    Well, I worked on the car for about 2 hours today. I can't get the damn EGR tube nut to go into the DC header, with everything attached like its supposed to be. It looks like the bot/nut is stripped a tad bit. The inside thread of the DC looks good. Anyone got any pointers?
  7. #257
    LXi User Catalyst's Avatar
    Dec 2006
    87 Accord Lxi Hatchback
    Murphys, CA
    JB weld =)
  8. #258
    Idaho
    Quote Originally Posted by Catalyst
    JB weld =)
  9. #259
    leave it unhooked if you dont have emissions to pass in your state.
    emissions FTL
  11. #261
    Dec 2003
    Millington, TN
    I had to pull the egr tube completely off to thread into the header.
    You'll have to pull the dizzy, H2o tube at the head. Its a bitch but its the only way not to cross thread the header.
    Phil
  12. #262
    Idaho
    What size of bolts thread into the dc header (hooking the header to the downpipe). My bolts from the paceheader are too big.
  13. #263
    Idaho
    I'll be removing that gay ass red oil cap cover soon, my friend gave it to me. My valve cover is filthy dirty too, needs a good wash job.
  14. #264
    Idaho
    This is the exhaust gasket I will need and many of you guys probably need.
    It goes to a Subaru Exhaust Gasket -Ex. Manifold to Block - 02+ WRX / 04+ STi or
    Subaru Legacy 90-95
  15. #265
    Idaho
    I don't have emissions, but wouldn't the car run like poopy?
  16. #266
    LX User skycam_313's Avatar
    Dec 2006
    88 DX Coupe
    hayward, CA
    get a tap and die set and have at that bastard... then itll fit for sure
    mods:
    stage 4 vacuum removal
  17. #267
    Idaho
    Just got back from the Subaru dealer and got this for $20.
    Subaru Part number is 44022AA020!
    The holes don't line up exactly, but i will use my drill press and drill them properly!
    This metal gasket has 5 layers!!!! It will seal like no other!
  18. #268
    Dec 2003
    Millington, TN
    DC Header paperwork describes them as M10-1.25 x 20mm. I got mine from Autozone (M10 X 1.25) for the used header I put on. Get them alittle longer M10-1.25 x 30mm so that you can use a nut for extra compression and a tight fit although its not needed I did. It keeps the bolt from backing out in my opinion.
    Phil
  19. #269
    Dec 2003
    Millington, TN
    Subaru Legacy 90-95
    Original Honda exhaust crush gaskets is what I used.
    Phil
  20. #270
    Idaho
    This header is being a real fucking headache, I've haven't been this mad at my car ever.
  21. #271
    Idaho
    Well, I got the header on. I took off all of the exhaust studs,put the header over the holes with the gasket on and rethreaded the studs but not all the way. I'm going to go get some longer studs so I can put them in all the way. I might just get some nice allen wrench bolts and use them instead of studs. I don't know, I'm going to sleep on the idea. I'm tired and I'm still 1/4 done. I still need to put the nuts on the egr pipe at the top where it connects to the egr itself. I'm praying it all works out in the end. I should have stuck with the pacesetter, it was easier, not as nice- but more friendly.
  22. #272
    Did you want the pacesetter back
  23. #273
    Dec 2003
    Millington, TN
    Its worth it. The easiest way is just to drain down the radiator, remove the dizzy and unbolt the water pipe this will give you all the room nessary to install the header. Its really not that much work.
    Phil
  24. #274
    Idaho
    How does the water pipe come out, does it thread in like a bolt? I've never taken it out. It is alot of work when I'm getting back into the groove of working on my car. I only got 5 hours of sleep after a day of busting my ass at work and then coming home to working on my car for an intense 3 hours. I'm sore to the bone now, and now it's round two. 3GEE PRIDE!
  25. #275
    Dec 2003
    Millington, TN
    Its the housing for the theromstat just a couple bolts if I remember correctly it has a rubber half circle gasket.
    Phil
  1. some more completed suspension pictures from the lost hatch
    Last Post: 07-10-2007, 11:53 PM
  2. My hatch is wrecked!
    By BITESIZE in forum Classic Honda Community Chat
    Last Post: 04-18-2006, 10:17 PM
  3. would like to find stock looking pictures of a hatch with the blue interior
    Last Post: 07-12-2005, 09:50 PM
  4. My Accord Hatch (for sale) many pictures
    By 89accordhb in forum Trading Post
    Last Post: 06-17-2003, 09:10 AM
  5. My Accord Hatch (for sale) many pictures
    By 89accordhb in forum Classic Honda Pics & Videos
    Last Post: 05-25-2003, 07:07 PM
