Okay, these are somewhat related and very common.
First, there is a rubber stopper/nipple thing on all our brake pedals. This breaks the circuit when the brake is NOT applied. Over time, this stopper wears out on most older Hondas. What happens next is two metal pieces touch when the brake is not applied. However, with no rubber to incomplete/open the circuit, your brake lights are always on. Yes, even with the car off. Cheap part, very common problem.
So, my battery runs down. On my car and my old 78 Accord, the positive (normally red) terminal has a black cover that protects it. If you're not 100% double checking, you will hook your jumper cable that is for the (-) to this post. The second you get all the cables connected (assuming your boost battery is good), you will see smoke and smell burning plastic. You blew the main fuse that is located RIGHT near the (+) cable under a cover. NOTHING will work and you can't jump it. This prevents current from frying other things in the engine. Again, easy fix. But it sux to have it happen. Also, you can get a group 51 battery or a 51R battery. We need the standard group 51. Otherwise, the terminals are switched around. The cable closest to the strut tower is the (+) on our whips. When replacing the battery, just be sure to doublecheck or you'll blow that main fuse again.
EDIT: The rubber stopper actually rests on the brakelight SWITCH itself. The stopper pushes the spring loaded button on the switch when the brake isn't being applied. So, when the rubber stopper is gone, the switch is activated at all times. Thought I'd clarify that.
