Does anybody have pics or diagrams of under the engines of 3g and 4g accords? Perhaps from a Haynes or Chilton's manual or better? OR just pics of the lower crossmembers of both cars themselves?
I wanna see how close the lower crossmembers look alike. If they are swapable, might make an h22 swap much more feasable. More importantly, the rear lower crossmember. The front 3g crossmember can be redrilled to bolt the h22 front mount on -- or use a 2g teg front crossmember with a Hasport h22 swap front mount for tegs. The driver's and passenger's side mounts can be taken cared of via CRX h22 swap mounts. The tricky one is the rear mount. But if the rear crossmember from the 4g could be swapped, the rear h22 mount would just bolt right in. I think you might have to swap to a 4g steering rack and reroute the power steering lines though -- or find a way to attach the 3g steering rack to the 4g rear lower crossmember.
Hasport hydro-cable clutch conversion lever takes care of the clutch engagement. 4g shift box and shift cables takes care of the shifting since the 3g's uses rods.
