Alright, background first... The car had a stalling issue, such that it would be a little tough to start, and when slowing to a stop it would want to stall. Also, when the ignition would shut off, the engine would fire a couple more times before it spuddered and stopped.
After this, the radiator went, so I've replaced that without a problem, but then I attempted to rebuild the carburetor (yes, my first carb attempt) with a budget GP Sorensen kit from Advance Auto. When I took it apart, it didn't actually look that bad, except for the air horn gasket. But, of course, I still sprayed carb cleaner on the lot of it, and in holes until it blasted out some other hole. I replaced what o-rings were included and such...put the booster venturis back on nice and tight. When dealing with the vacuum hoses, I used 5 different-colored paint markers to mark them upon disconnecting them, so I don't believe the problem is related to that easy-to-make mistake.
I had a bit of an issue with the float... The hinge could only be tapped out, which I managed to do (in order to replace the needle and seat), but upon putting it back in, the hinge bent slightly...slightly enough to start cracking the hinge on the plastic float. It was just a little split, and not where fuel would get in, so I super glued it, and I used a large paper clip, bent around to jury rig it in order to keep it from wiggling about.
The other thing that puzzled me is the choke opening mechanism. I pulled the throttle lever all the way and then let it back, which the factory service manual says the choke should shut all the way afterwards...which it did not. It would return if the throttle arm was resting against the part of the little arm with the choke return spring, basically holding it in position with friction...but that little arm has notches in it, as if to catch the throttle arm when the choke is closed or something. Anyway, even with no bimetallic spring attached, it barely returns even when held...so I'm thinking the spring is out of whack... I was thinking of attaching a throttle spring or something directly to the choke arm and attach it however far I need to adjust the tension, but I'm not positive enough on exactly how it's supposed to act to do so. However, I don't believe the choke alone could be causing my problem...
That said... I got the carburetor back on, and replaced the secondary fuel filter (I have the primary, which I'll get to next as well as test the fuel pressure), and it was like before, but worse... I adjusted the float screw and screwed in the idle stop a bit, and now I can get it to start with a wee bit of pedal (or none if it's warm and I'm lucky), and actually it will run around 1200 rpm without me holding the pedal, but it sputters and coughs like a 60-year smoker. Also, before I worked on it, the idle would begin around 2,200, which as I understand it is the fast idle engaged...which it didn't appear to be this time. 2,200 seemed way too high to me anyway, but upon reading the service manual, it sounds like it's supposed to...but even with the engine warmed up, it sputters at 1,200, which I know is not right, and I need to address that first... It basically sounds like it's starving for fuel. If I press the pedal, and up it to over 2 or 3k, it will smooth out, but still give a "blip" sputter every few seconds. As I have it now, it will actually keep going in gear and go down the road with rather menial power...which is how it was before lol... Sorry about being so long, but I wanted to give as many details as might be needed... I'd appreciate if I could be shoved in the right direction because I'm used to fuel injection and Cadillacs...help![]()
