Results 1 to 6 of 6
Thread: How to remove door panel on 4 door LX?
    LX User bushbean's Avatar
    Howdy folks,
    Got another query for ya. My front power window clunks and moves real
    slow, so I need to remove the door panel to see what's going on with
    the lift mechanism. Could someone give some pointers on removing the
    door panel?
    Thanks yall!
    A pickup-drivin' Texan
    Re: How to remove door panel on 4 door LX?
    you unscrew everything in the way, theres 3 big screws in the big thing on the door, dont forget them, once there out, pry off the thing on top (i think its a chrome trim) pry it upwards, best with the window down,, but if it wont go down its ok. get a flat head screw driver, put it between the panel and door, feel around for little clip thingies holding it in, pry them out (carefull not to damage the door panel as its only like cardboard. once you pryed them off, lift the panel up and out, then unplug what's in the way
    1ajs's Avatar
    slurpeepeg
    i think the manual shows you how to do this also
    SE-i Sedan 5 spd
    Get a panel tool at an auto parts store. It's kind of wide and flat with a bend in it. It has a notch to fit around the plugs holding the panel to the door. Take out all the obvious screws...latch, armrest, etc. On my 89, there's a small circular (dime-sized) cover over a screw just behind the speaker grill.
    Once all the screws are out, take the panel removal tool and insert it between the panel and the door frame. Try to do it where the plugs are. The tool's notch will allow you to leave the female plug in the door, and pop out the male plug in the panel. Once the panel is loose, lift the panel up and out of the door frame from the rear first, then kind of pull it back from the front window frame. Note that there's a little foam wrap/spacer around the door lock button. Make sure you put that back when you put the panel back in, or the lock button may rattle on you.
    If you're the ambitious type, now's the time to lube the window mechanism and clean the contacts on at least the driver's door window switch. When you're unplugging the wire sets, clean the plugs with electric contact cleaner (comes in a spray can).
    Good luck.
    LXi User TheWatcher's Avatar
    Feb 2005
    1989 Honda Accord LX
    It literally should take about 5 minutes to pull the door panel.
    Ditto on using the panel tool. I bought mine at Checkers.
    Make sure all the screws are removed and remove the wire harness(es) if any.
    I like to have a "helper" when putting the door panel back on, since you have to hook up the wire harness(es). It's easier to put the harness on, if you aren't using one hand to hold up the door panel (hence my preference for a helper to put the door panel back on). Of course, you can replace the door panel w/o any help, but it takes a bit longer.
    If the plastic door liner is no longer attached correctly, now is the time to tape the plastic door liner back in place.
    Peace.
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    One in the same.
    Matco door panel removers.
  1. how do i remove my interior door panel?
    Last Post: 03-27-2007, 04:28 PM
  2. door panel
    By ninja2571 in forum Interior & Exterior Care
    Last Post: 01-29-2004, 01:55 PM
  3. Replies: 6
    Last Post: 12-30-2003, 01:16 PM
  4. door panel
    By AccordArizona89 in forum Interior & Exterior Care
    Last Post: 09-05-2003, 01:38 PM
  5. WTB: door panel
    By jlaccord89lxi in forum Trading Post
    Last Post: 08-16-2003, 11:21 AM
