Results 1 to 9 of 9
Thread: CLUSTER Doesn't Work
    LX User Listen2myBASS's Avatar
    1989 Honda Accord LX-i Coupe
    Born in Chicago moved to Plainfield...
    GAUGES and H.LIGHT ASMBLY
    i re-did my gauge cluster by putting blue LED's in, but now it doesnt wanna turn on? i hooked up the 4 harnesses but not the main one the goes to the speedo. also, i took my headlights out to replace them with some H4 conversions, but now i can't seem to get them back in. is there a diagram anyhwere that's reallyin depth? any info is appreciated.
    Re: CLUSTER Doesn't Work
    im not sure but i think u have to have the wiring harness for a h4 conversion
    no special harness they should be just like your autopal housings Ghetto
    no, not like they don't work, i checked em, they work, hi's and low's, its just i cant get them to stay in place in the headlight assembly, i have em in the housing, they're in the silver trim, but i cant figure out how they stayed in before. see what i mean?
    hang on I'll get a diagram up on the screen
    nevermind my alldata isnt showing a picture
    damnit, any ideas about the gauges not lighting?
    ya but i have th h4 up grade harnees for more power
    SEi User B16KILLA's Avatar
    SO,CAL
    Quote Originally Posted by Listen2myBASS
    did you check the fuse. if it's not blown take it back apart and triple check everything.
    ill check it? but the brake, seatbelt, hi-beam, and check engine light work? diff. fuses? this is gay, ill check with a stock light when i check the fuse as well...
  1. Passenger window doesn't work
    Last Post: 01-26-2011, 05:06 PM
  2. headlight motor doesn't work
    By coope in forum Performance
    Last Post: 05-07-2007, 08:52 PM
  3. Radio doesn't work
    By MrBen in forum Interior & Exterior Care
    Last Post: 07-17-2003, 10:03 PM
  4. ***HELP....HELP*** 5th Gear Doesn't Work!!!
    By 89AccordLXI666 in forum 3geez Accords
    Last Post: 01-04-2003, 12:27 PM
  5. My hood release doesn't work
    By 87DXHatch in forum Classic Honda Community Chat
    Last Post: 12-05-2002, 08:22 PM
