Results 1 to 25 of 26
Thread: The Donor Car gets partly stripped today...
    LXi User RamThis's Avatar
    N. Richland Hills, Tx
    Getting ready to prepare for the LX-I swap. I have the interior gutted to access the harness under the seats and access to the fuel pump. Still need to pull the dash though. Got the fenders off as well to access the harness behind them.
    Any odd things to look out for??
    Car from front
    Interior Gutted
    Harness behind passenger fender
    The twins
    The twins again
    View my Image Gallery
    1989 Honda Accord LX
    2006 Toyota 4Runner SR5
    1996 Dodge Ram 1500
    2000 Dodge Ram 1500
    MY 3G UPDATE THREAD
    Re: The Donor Car gets partly stripped today...
    You will save yourself a lot if time if you pull that dash out. There are alot of hard to get to wires with it there. G/L dude keep us up to date
    It's on the agenda just didnt have time to get to it. I only had a couple hours time between family gatherings lol I did all that in two hours, not too shabby I'd say, and it was careful disassembly, not rip and tearing it apart. I'm taking this one apart carefully to understand how mine will come apart so I dont break anything upon disassembly. Hopefully when the time comes to pull mine apart, I will already know all the clips and fasteners and tricks to getting it apart safely. Putting it all back together will be a whole different story LOL.
    1996 Dodge Ram 1500
    2000 Dodge Ram 1500
    MY 3G UPDATE THREAD
    Congrats Not bad it all for just two hours!
    Don't forget the DEAD PEDAL/FOOT REST for your LX
    Apr 2006
    2007 Cobalt LT Coupe
    Moose Jaw, Saskatchewan
    AND the LX-i logo
    Quote Originally Posted by RamThis
    ya u fining out how much it would be to ship that dash to me in 94509 lol
    lol that is one clean strip...i wanted to take out my carpet and i had to take out everything it took a buddy and me 2 hours...mine is a DX so i only have the fart sensor on the seat and the ecu...non of the other stuff...it was fun...we even took off the door panels. i got them painted but im only half way done on puting it back together.....btw i love your accord...so freaken clean....its going to be sweet when its fuel injected.
    Awesome job
    Im going thru the same thing right now with my donor car.
    Have lots of fun and enjoy
    Good luck with the swap....
    Thanks guys, I have LOTS more to come for sure LOL.
    And if you are serious about the dash ghettogeddy, I will weigh it and measure it and find out how much it woudl take to ship. I will look it over for you to see if it has any damage, but I think I remember it being pretty cherry.
    I can't wait to get the wiring harness out and inspect it and re-loom it. That alone will make the underhood area of my car look great, that nice new-looking harness, a freshly painted engine, and all washed up under the hood. Looks like I'm keeping this car a while LOL.
    1996 Dodge Ram 1500
    2000 Dodge Ram 1500
    MY 3G UPDATE THREAD
    1ajs's Avatar
    slurpeepeg
    what was rong with the parts car? to become a parts car???
    Quote Originally Posted by 1ajs
    Bad tranny, and I believe he said coolant came out of the piston.
    Well no, no coolant leaks on the parts car, the engine still runs pretty good as is. It's a parts car because it is totally faded out paint, Nasty interior, busted out back window, busted up windshield, bad oil leaks, power steering seems to be out (no fluid and has bad leak) and the trans quits working after it warms up. Car could be nice with some work I guess, Well ALOT of work, but my car is so clean as is, I'd rather just use this one for the mechanical parts I need that are good, and make my clean car run with the LX-I harness and engine.
    All I gotta do is disassemble two cars and put one back together again, how hard could that be????
    1996 Dodge Ram 1500
    2000 Dodge Ram 1500
    MY 3G UPDATE THREAD
    then u can put a v8 5.0 in the parts car and make it straight drag lol
    Sadly enough, I've already thought about that.......
    No shittin, I had told the wife I thought it would be cool to completely strip the car, cut out the suspension, channel the body and put it on a modified two rail chassis from an older car that had RWD with a big V-8, weld in a roll cage, do a paint job on it, drop in a built up 350 SBC, and voila, Instant 2500LB drag racer!!!
    1996 Dodge Ram 1500
    2000 Dodge Ram 1500
    MY 3G UPDATE THREAD
    do it do it do it , and make sure u dont get rid of the pop up lights lol
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    Do a compression test on the used parts car motor. That allways gives me a sense of knowing what shape the motor is in before I drop a used motor in any car.
    Do a compression test on the used parts car motor. That all ways gives me a sense of knowing what shape the motor is in before I drop a used motor in any car.
    Thats what we did on the donor car I got luckily compression was 160 on all 4 cylinders
    Compression dont matter to me, I'm fully rebuilding the engine before I drop it in anyway, all new bearings, rings, seals, rebuld the head, deck the block to true it, hot tank it, paint it up, bolt it all together, and slap it in the car! Hopin it runs like a new one, or better....
    1996 Dodge Ram 1500
    2000 Dodge Ram 1500
    MY 3G UPDATE THREAD
    Can't do that, they're part of the "charm" of these cars so to speak lol. Lose the pop-ups, lose the charm!
    1996 Dodge Ram 1500
    2000 Dodge Ram 1500
    MY 3G UPDATE THREAD
    thats what i like to hear. so are u gona do it lol
    If I do, it will be a while LOL. I got lots of other things I gotta do before I can start on another project, seems I got ten of them going at all times for some reason, and none of the mofo's are ever done!!
    1996 Dodge Ram 1500
    2000 Dodge Ram 1500
    MY 3G UPDATE THREAD
    lol thats the way it is lol
    Just a couple of the things I need to do...
    Cut the roof out of the 2000 ram and weld in the new one Ive had in a box in my shed for about three years. (hail damage)
    Fit and Paint that damn Harwood Ram Air hood on that same truck.
    Install the Roll Pan and Tailgate Handle Relocator on that truck too.
    Paint that truck
    Replace the hood, front bumper, and passenger fender on my Acura. (hail damage, wife's garage rash)
    Fix the parking lot rash down the sides of the Acura
    Totally strip down and repaint the Acura
    Tear the race engine out of my 96 Ram and sell it, and drop in a stock 360.
    Fix the interior up some on that truck.
    Repaint the truck.
    Completely redo our master bathroom and bedroom
    replace our rotting and nearly falling down privacy fence around the back yard
    Add on a back porch to the house
    Have a street access poured to the extra parking area we had poured some years ago
    finish painting the eaves and trim on the house (house is 9 years old now and already has had a new roof from hail, and the TX sun has eaten the paint up bad on the eaves/trim)
    That's some of the bigger projects I got going on right now........
    1996 Dodge Ram 1500
    2000 Dodge Ram 1500
    MY 3G UPDATE THREAD
    Sep 2006
    Red face Re: The Donor Car gets partly stripped today...
    I am actually going to do this also. I have a 1986 dx with a blown ring and a 1986 lx-i with a bad tranny and loads of body damage. The only thing I am kinda worried about is if the 5 speed tranny from the dx will bolt up to the lx-i, same block so it should, but still kinda worried. Oh, and how much HP can I get out of the a20 block if I were to rebuild it for boost, like dropping compression, forged internals, stuff like that. And is it worth it?
    3Geez Veteran gfrg88's Avatar
    1986 Honda Prelude 2.0Si-T
    A Mile High.
    Quote Originally Posted by japcarsrule
    yes its worth it and it depends on what you do to get certain hp.
    -Gio
    My E85 Turbo Build
    5280FEST
  1. Free Donor Car
    By brownj218 in forum Classic Honda Community Chat
    Last Post: 05-31-2007, 03:49 PM
  2. Tearing down donor car..What to keep?
    By ex1z7 in forum 3geez Accords
    Last Post: 06-24-2006, 09:31 AM
  3. My new donor car....
    By 87accordHB in forum Classic Honda Pics & Videos
    Last Post: 02-28-2006, 10:43 PM
  4. Donor Cam
    By HondaBoy in forum Performance
    Last Post: 06-29-2003, 06:09 PM
  5. a camber kit donor???
    By markmdz89hatch in forum Suspension/Wheels/Tires/Brakes
    Last Post: 06-24-2003, 04:16 PM
