ok this should be the last or 2nd to last thread to do with my car problems.. anyway.. here's what happens.
car is cold, start it up, no high idle or anything and will stall if i dont assist the accelerator. i sit on the accelerator holding revs between 1500 - 2300RPM, the tempature needle goes up, car is warm, but still idles like poop and if the revs drop near 1000rpm and throttle it, it takes for ever to respond. its like it wants to stall (like im flooding it or something) and once it passes 2000rpm its fine :S so anyway, just turned the car off and then about 10 minutes later, start the car and it sounds fine, no weakness when you throttle it or anything like that, but it will idle at 2000rpm when its warm and only if the car has been shut off for a few minutes, this has happened 4 times so far, what would that problem be? just seems weird that it will idle high when warm and idle low when cold. TIA
i tried searching but wouldnt have a clue what im doing
