i was just wondering if anyone has a short throw shifter in there car and if they could get a pic of it up?
i emo'ed mine, i mean cut mine if that counts lol
does it really help with shifting at all like can you shift a lot quicker? and it's adjustable throw so can you chang the angle it's set at?
its adjustable to make the shifts closer. if you just cut the stock one down it doesnt do anything. this has been covered before, just search it you n00b!! lol j/k.Originally Posted by sinisterfuzzy
il take pics of mine when i get home.
ya hes right just cutting it dosent make it shift any better but mine is a little more stiff then stock due to not enouight leverage but i couldent stand the mile high stock sizeOriginally Posted by gfrg88
Originally Posted by ghettogeddy
Do yu have the paceseter?
I have the same problem with mine and its a pacesetter. It sits where I want it to and the distance between shifts is alot shorter but its lost its leverage so its a little harder to shift. Gonna have to find a way to fix it to cause its getting old already.
i know what this is, have you ever kinda hit the shifter down?? try and you should hear it hit against the heat shield. thats what was making mine hard, i cut the heat shield and now its smooth. but im going to adjust it a little more so it can be shorter.Originally Posted by guaynabo89
no mines just a cut stock shifterOriginally Posted by guaynabo89
i used to have short shifter. had it for less than a week. didn't like it. I like the feel of stock shifter. IMO honda has small shifts from the factory. Plus a lot of honda transmissions don't like short shifters because they are build very tight.
i have to order the poly bushing for it b4 i put it on.
i was thinking of doing thatOriginally Posted by ghettogeddy
i took like 3 inches off
no my heat shied is cut to make room for the shifter and it has fresh mtf. With the pacesetter you just loose leverage when you bring it down there fore making it take more effort to shift than stock.
