The exhaust is a pacesetter 4-2-1, 2" for the most part
Intake, some sort of custom manifold, havent worked it all out yet, but there will be a weber sitting on top. Was going to be a 36/36 but it may be too big for low end response.
Headwork: DIY port job, wont be too wild but too smooth things out for the most part. Exhaust will be ported more than intake. Would prefer to keep costs down by using a pre-made staged cam instead of a custom grind, so a stage 1 should be suitable. Ill get it decked at a machine shop and get a mild angle job
Compression is at an 87 motor right now, so im thinking if I get pistons ill go with 9.5-10, just getting the cylinders honed, with 20xxxxkm on motor a hone job may be equivalent to 20 over.
Bottom end: Pretty much stock, ill get new main bearings etc, but I imagine using stock rods/crank will be fine, maybe get them lightened a little.
Flywheel, just a lighterweight stock one, not much less weight.
Ignition: Some sort of MSD coil, will try out that quad coil mod I was thinking about, but im not expecting a whole lot from a theory.
What can I do to have a flat curve? Id rather have 120 across the board than 90 below 3000 and 150 above, you know what I mean?
