Results 1 to 25 of 30
Thread: Stock Stereo Specs.
    LXi User DDRaptor's Avatar
    1988 Honda Accord LX
    Bronx, NY
    Stock Stereo Specs.
    I have searched for specs on the factory radio. come up nil.
    I want to know what are the stock specs and how much can it power.
    right now it has 4 6" 15W speakers that equals 60W total and i have 4 tweeters inline with each speaker.
    Also if it's possible to connect a sub with a common ground with all the speakers so it gets more bump. not super large maybe like a 7-8" sub.
    THanks for info.
    89LX or SE-i(yeah right)
    Re: Stock Stereo Specs.
    well trying to add a sub would mess with impedence(ohm's) i personaly wouldent hook a sub up to a stock deck with out an amp it will eather mess the deck up or mess the sub up
    LX User Listen2myBASS's Avatar
    1989 Honda Accord LX-i Coupe
    Born in Chicago moved to Plainfield...
    it will, most likely, blow the amp on the deck since it would be pulling so much power that your deck probably doesn't have.
    stock radio sucks, shitcan at once.
    Bronx, NY
    actually i love my stock radio it bumps my car plenty SInce i grounded the car with that 4 guage wire. no noise, or static or anything.
    i'm just trying to figure if i can buy 4 new 6" speakers with higher wattage.
    and the sub i would need some sort of AMP, amps ar'nt hard to build.
    yeah i would not recomend any subs on a stereo...me being the example...i pluged in my 10 inch sub to my deck and now my deck is weak....the internal amp is slowly dieing.
    carotman's Avatar
    Montreal South Shore
    If the amp has high inputs (speaker level) it could be used to drive a subwoofer.
    Bronx, NY
    Don't think it has high level according to this.
    Heres the problem 6inch speakers are'nt really made so i guess i have to get 4 6.5" speakers
    Forum Bot.
    Here are the color codes to hook-up a radio to your 3rd gen. I strongly recomment you buy an adapter that will allow you to keep your original harness but if it's already missing, cou can use this code
    ________________________________________
    function ............................color/stripe
    12v constant .....................white/yellow
    12v accesory .....................yellow/red
    12v ground ........................black
    dimmer (lights) ...................red/black
    Left front (+) .................... Blue/Green
    Left front (-) .................... Grey/Black
    Right front (+) .................. Red/Green
    Right front (-) .................. Brown/Black
    Left rear (+) ..................... Blue/Yellow
    Left rear (-) ..................... Grey/White
    Right rear (+) ................... Red/Yellow
    Right rear (-) ................... Brown/White
    on the eq output there is a low level output
    https://www.3geez.com/forum/showthread.php?t=44949
    Code:
    (diagram is show as if you were looking at the
     male pins)
     7       1      1 blue   - left stereo out (from HU
                     2 white  - left stereo in (to HU)
    6    8    2    3 black  - ground for stereo in
                     4 orange - ?
     5       3      5 red    - power ?
         4           6 yellow - right stereo in
                     7 green  - right stereo out
                     8 black  - ground for stereo out
                  The metal ring around the outside
                  of the pins is the ground connection
    Bronx, NY
    What EQ? i don't have any. your post just got me really confused
    LXi User Crazybird's Avatar
    89 4 door accord lx
    winnipeg
    lol u actaully like ur stock stereo and u say it thumps..... perhaps u should get into one of our cars that has a good stereo and then ull see what bumps for little money
    Bronx, NY
    trust me personally i hate super loud radios in cars. I'm happy with it. just trying to find out the Wattage output, without having to resort to my school smarts.
    Power (W) = V X I
    yada yada yada and all those neat things from DC/AC class.
    no theres a 8pin connector on the back of the stock stereo u should be able to tape into the lines directly and use them as a low level output
    Bronx, NY
    ok that connector is obviously seperate from the other harness with the speaker out puts. i think i understand now. the how to on getting the radio out has no pictures anymore but it should'nt be so hard.
    So if what your telling me is right that extra connector leads to nowhere on my deck since i don't have an EQ. So how exactly would i use those connection, cause according to your posted code it also has an input so can that be used as a permanent input?
    thanks for clearing up your post.
    yes u are right about the in im not sure if u need the eq or not i know frantic has made a working input but like i said im unsure about the eq part
    and as far as getting the stock steroe out there are 2 screws in the back and i belive thats it
    i have a $19 150x2= 300 watt sub from kregen in my car it sounds great with my 150 watt 3way spekers all on the stock lx-i radio
    but its still not loud enuf for me must get 1000000 watt system
    well as of right know im just running 4 5 1/4" polk audio db series and they sound awsome but i have like no lows at all im also running them off of a stock prelude cd player
    heres a couple or pics of my old systems
    1st
    3 sony p5 10"s
    2 fosgate amps totaling 2400 watts and my audiobahn a4004t 400 watt 4ch
    and 2 caps one being 1.5 fared the other is 1 fared
    2nd
    my audio bahn a4004t (the little one)
    and an audiobahn a800t mono block 800x1 at 2 ohm
    pushing and alpine type r10"
    no cap
    Bronx, NY
    damn that's alot of s*^t, that install looks clean. well anyways tommorow is street cleaning day so i have to move the car regardless now i have to take out the radio and take some pictures. And i'll put my skills out there and use my multimeter to meter the AC volts and the current and try to figure out stock output wattage.
    Quote Originally Posted by DDRaptor
    witch install looks clean lol
    when i took out my dx speakers i think they said 30 watts....so it could be 120watts? for speakers so the stereo should be around that
    that seams like alot for a stock stereo more like 15watts a ch sounds better
    Bronx, NY
    both those systems, but i happen to like my trunk space.
    mine are defintly 15W printed on back.
    ya i love the trunk space i have know but even with the one 10 i had alot of room in there
    im not sure if it was 30watts or 15.....btw it just said high powered on the honda deck. but yeah if the bose se-i can with 120 watts amps our cars must of came with 60 watts.
    Bronx, NY
    the pictures make is seem kinda bulky, you had 2 caps 2 amps a 10inch. I'm thinking it could be between 60-120Watts max. cause i have 15w speakers, he has/had 30 watt speakers which would make sense since speakers have regular inputs and their max input is around double the regular input.
  1. Anyone Looking for a Stock Stereo?
    By gyates93 in forum Interior & Exterior Care
    Last Post: 04-21-2012, 12:58 PM
  2. stock cam specs
    By InAccordance in forum 3geez Accords
    Last Post: 07-23-2010, 04:03 AM
  3. Stock Specs?
    By maxsideburn in forum Classic Honda Community Chat
    Last Post: 11-10-2005, 04:54 PM
  4. stock wheel specs
    By nobigtoe in forum Suspension/Wheels/Tires/Brakes
    Last Post: 03-05-2004, 07:02 PM
  5. 89 LXi stock stereo/EQ/cd
    By SPDboy in forum Interior & Exterior Care
    Last Post: 03-16-2003, 03:41 PM
