Results 1 to 18 of 18
Thread: injector seals
    88 honda accord lx-i
    altadena, cali
    Question injector seals
    damn, the seals on two of my injectors are bad. im starting to leak fuel onto the manifold. how do u change them, because my other two, but im going to change all four sets. help
    Feb 2004
    Panama City, FL
    Re: injector seals
    Just remove the clips from injectors then remove the four bolts that hold the fuel rail down. Pull the fuel rail up away from the intake manni and then pull the injectors out and replace the seals. Then reinstall the reverse of the removal. You may need to twist the injectors a little to get them to come out.
    Pgm-fi conversion 4-16-05
    OBD1 11-25-06
    Turbo 2-26-07
    Idaho
    Re: injector seals
    Quote Originally Posted by EricW
    Its easy too.
    AZmike's Avatar
    Tucson, Arizona
    Re: injector seals
    It's common for the seam between the metal and plastic parts on the injector itself to be the source of the leak. Replacing the external seals may not solve the problem.
    Mike
    Mar 2006
    1989 LX-i Coupe
    Re: injector seals
    Did a better search and realized I most likely need to replace the injectors. When doing so - ANything special I should be ware of.
    Sorry to jump in but if the seam is the issue - what needs to be done.
    I ask since I had all four replaced in 09/05 and the number 4 injector (I think is still leaking).
    Thanks
    Re: injector seals
    When I did my seals the torque of the nuts that hold the fuel rail down is critical.On first try I just tightened it all up pressurized the system and got two pretty big leaks. I think the torque is like 10 ft/lbs but look it up and always check for leaks before driving.
    And yeah its my injectors that are leaking.
    Blkblurr's Avatar
    Dayton, Ohio
    Re: injector seals
    once the seam leaks your injector needs to be replaced.
    Hash_man_Se_i's Avatar
    Calgary, AB, Canada
    Re: injector seals
    Definately the injectors... go to a pick and pull type of place and grab a set.
    I just followed the instructions from the FSM on www.pauldesign.ru ... Paul did us a great thing uploading it to his site.
    Just find the section for the fuel system, and download the file... gives you very very easy step by step instructions.
    LX User Estimated Prophet's Avatar
    Mar 2007
    88 LX-i Hatch MT
    Atlanta, Ga
    Re: injector seals
    I have a leak in one of mine also. What other models have injectors that I can use on my 89 LXi? I work at a Honda junk yard but we do not have a whole lot of pre-90 cars.
    Re: injector seals
    Quote Originally Posted by Estimated Prophet
    i think 4th gen accord ones work but they still flow at the same rate. i heard that prelude h22 ones work but im not sure if they would just swap in.
    Re: injector seals
    I have the 4th gen ones in my car
    Re: injector seals
    but does it run?...... jp with you man...lol so this sat is going to be running right?
    Re: injector seals
    YES......I Hope
    Re: injector seals
    YES......I Hope
    sweeet......i found out i dont work on sat....guess who may be coming?...lol
    Re: injector seals
    Cool....
    Get ahold of everone else....Lets BBQ
    Mar 2007
    88 LX-i Hatch MT
    Atlanta, Ga
    Re: injector seals
    What's the difference between these two other than one is half the price?
    http://www.partsamerica.com/ProductL...ector+Seal+Kit
    Honda Parts Connection -- http://www.acurahondaparts.com
    D Series Army Dishonorable Discharge
    BT Defector
    Feb 2004
    Panama City, FL
    Re: injector seals
    I think that's pretty much it. Maybe quality but I don't know much about either company other than beck is a pretty big in aftermarket replacement parts.
    OBD1 11-25-06
    Turbo 2-26-07
    Mar 2007
    88 LX-i Hatch MT
    Atlanta, Ga
    Arrow Re: injector seals
    FYI I checked Hollander and according to it(but it isn't always accurate) the following injectors interchange with my 89 Fed LX-i:
    Integra 86-89
    Integra 90-91 Fed.
    CRX Si 88-91 Fed
    Prelude 88-91 Fed
    BT Defector
  1. Door seals
    By beckypumps in forum Classic Honda Community Chat
    Last Post: 12-11-2009, 06:07 PM
  2. Valve seals
    Last Post: 11-07-2009, 04:38 PM
  3. injector seals
    By gp02a0083 in forum 3geez Accords
    Last Post: 05-26-2007, 08:32 PM
  4. Aftermarket oil seals
    By Dutchboy in forum 3geez Accords
    Last Post: 11-19-2004, 09:03 PM
  5. Valve seals
    By Sabz5150 in forum 3geez Accords
    Last Post: 03-01-2004, 02:39 PM
