Results 1 to 16 of 16
Thread: Key Won't Turn
    LX User Listen2myBASS's Avatar
    1989 Honda Accord LX-i Coupe
    Born in Chicago moved to Plainfield...
    Key Won't Turn
    every time my battery has died, it's been a little hard to turn the key, but this time i can't turn it at all, it's stuck. i have no idea why either. any suggestions?
    Re: Key Won't Turn
    bump, i need this car jumped today asap...
    2ndGenGuy
    Guest
    Re: Key Won't Turn
    It sounds like your igntiion switch is broken. My Bronco did the same thing. I had to jam a screwdriver in it and use some plyers to turn it. The only other thing you can do is hotwire your car. But hotwiring won't work if the steering lock is engaged. You'll have to drill the ignition lock out or find the security bit that has it held onto the steering column.
    Re: Key Won't Turn
    %$^$@##@!#%^$&^*$%##@#$#$%@* damnit, wtf...im slapping someone...theres gotta be another explanation, thanks for your input though, now i know what to do if that is the problem...
    Re: Key Won't Turn
    get a new key ingnition...they sell some with keys on ebay....or get a new one but its going to cost hella money(not sure how much)
    snoopyloopy's Avatar
    Killa Cali
    Re: Key Won't Turn
    try turning the steering wheel while turning the key. because my car did that to me one day and that's what ended up being the problem. and if it feels like it doesn't want to turn, keep trying.
    Re: Key Won't Turn
    kool, ill try that when my friend brings his jumppack over.
    LXi User Crazybird's Avatar
    89 4 door accord lx
    winnipeg
    Re: Key Won't Turn
    umm ive had trouble getting my keys out and ya id try turning the wheel orrr are u still in gear cause mine did that to me once it was a weird situation
    Re: Key Won't Turn
    no, it's not that i can't get it out, it's that i can't get it to turn over...(put key in, turn key to ignite car)
    89 4 door accord lx
    winnipeg
    Re: Key Won't Turn
    so u cant get the key in at all??
    2ndGenGuy
    Guest
    Re: Key Won't Turn
    Sooo... the key phyically won't move in the ignition? Or the starter won't turn over?
    Re: Key Won't Turn
    i can get the key in, but i cant get the key to turn, at all, i put it in and theres no play at all...sorry if u thought some other way...
    2ndGenGuy
    Guest
    Re: Key Won't Turn
    Aah ok, so what I said earlier was right then. Its probably just worn out. The key could be worn or the teeth inside the tumbler are worn... Or like the other people were saying, the steering lock could just be acting like a bastard. Rock the steering wheel back and forth while trying to turn the key, sometimes that works...
    Re: Key Won't Turn
    ok, thanks everyone! and it would have to be the tumbler, b/c i try it with the old one, and the new one i just got made...
    Re: Key Won't Turn
    try the original keys...my car came with 2 master keys....one is worn to hell and the other one still looks brand new....i dont think a copy of a mest up key would help it.
    Re: Key Won't Turn
    my friend showed me out to start cars without key take a falt scredrive and put the scerwdriver where the key gos and hit it with a hammer and bust the part where the key gos out, once its gone take the scerwdriver and put it in where the key used to go and turn it and watch it start just dont get pulled over and make sure you lock your doors
  1. AC will not turn on
    By richduck in forum 3geez Accords
    Last Post: 09-20-2010, 07:28 AM
  2. It Won't Even Turn Over!!!!!
    By 1987HondaAccord in forum 3geez Accords
    Last Post: 06-08-2003, 07:44 PM
  3. **turn Off**
    By jigga89SEi in forum Classic Honda Community Chat
    Last Post: 05-28-2003, 07:02 AM
  4. Why does my system turn off when I turn on my heater?
    By 89AccordLXI666 in forum Interior & Exterior Care
    Last Post: 03-02-2003, 01:18 PM
  5. HELP can't turn key
    By toastyghost in forum Interior & Exterior Care
    Last Post: 06-30-2002, 12:14 AM
