Will a EFI intake manifold work a carbed accord? will it bolt up? a few holes to plug? will it give anymore power?
thanx
thanx
not sure if you could use to to make a custom dcoe manifold... maybe use the injector holes as nitrous ports. the hole set up as itself you might as well convert to efi.
see the problem with the efi manifold is that delivering fuel will be difficult cause most of the fuel will be sucked in by the intake runner that is closest to the carb the one furthest from the carb will barely get any fuel or none at all.
maybe if you split the manifold and ran 2 keihins on either end with 90 degree elbows to feed into the manifold and a wall inserted in the manifold to split the runners
