First off is there any way to check engine codes(i.e., ecu codes for check engine light) my check engine light came on tonight while driving but after I got home and shut off the car then restarted it there was nocheck engine light, anyone had similar probs?
2nd- my car has been having starting probs the past few weeks, it is not every time you start it just every once in a while. When I crank it up it will start and then shut right back off, then you try to start it again and the motor will just spin and spin but not fire over, then after trying a few times it will start up again and be fine for the next 20 or so starts.
Any idea's?
hope someone can give me some pointers on this, thanks
