Page 2 of 2 FirstFirst 12
Results 26 to 44 of 44
Thread: L24458 oil filter discontinued?
    Re: L24458 oil filter discontinued? Updated
    Have no clue. It was on the shelf at Advanced auto parts and it matched my list. Ill try and get another an shoot some pictures along with the Honda filter and the correct Pur. filter as well.
    AZmike's Avatar
    Jul 2002
    Tucson, Arizona
    Quote Originally Posted by Oldblueaccord
    I changed out the trans fluid as well as as the power steering fluid. Putting the plug back in the oil pan I realized i got a split CV boot so I need to change out the shaft this week so much for new trans fluid it will have to get drained again
    You could always drain in into a clean container and reuse it.
    Mike
    Accord of the Year - 2006
    guaynabo89's Avatar
    FL
    whatever happened to this?
    any leaks?
    pics?
    Got about 2400 miles on it running good so far. As far as pictures well heh I can take them but to get them set up takes me alotta time I just havent found sorry. I'm more of a car person then a computer person.
    PM a public E-mail and I will shoot some here in a day or two. I gotta take a bunch of junk chinese/india made parts back to AA anyway and I ll get another one and try to figure out what car it goes on.
    SEi User gp02a0083's Avatar
    1989 Lx-i Hatchback
    Jackson, NJ
    wow u guys r using 5-30 and 5-40 dam i thought b/c my engine got 135k on it i went to 10-30
    3Geez resident body man
    Owner of Wreck-less auto body
    Huh
    I use 10-40 summer 10-30 one change winter Havoline. 271k and counting.
    Ichiban's Avatar
    North of You.
    Ha! I run 15w-40 CL-4 in pretty much everything, from the chev's 350 to the Toy's 22R. The current clearances on the 22R are 0.0021 mains and 0.0018-19 on the rods. The engine builder in town here actually recommends Diesel grade engine oil for the detergent additive package and extra film strength. I run an AC Delco PF-13C filter on the toyota, which happens to be identical to the Mopar filter for the mid 90's truck engines. Seems they're both made by Wix. They're the same size, shape, screw thread, and both have a "3" and "4" stamped in the same place in the same font on the top of the filter. I'm also pretty sure that the Motomaster filters from Canadian Tire are not Fram, as I use a Motomaster instead of the Fram on my 82's 1.6l. Its almost twice the size as the Fram. I bet Wix, Purolater and Bosch make 90% of the OE filters out there.
    ICHIBAN!
    "Now, even more better!"
  8. #33
    LX User StressSolutions's Avatar
    88 LX
    Rochester, MN
    One of my other cars is a Hyundai XG350L...3.5 litres, which is a lot bigger than the Accord 2.0, yes? SAME oil filter.
  9. #34
    Just wanted to update this with a picture and all. I'm on the second one so far so good. I'm not sure if there would be a problem with this filter on a carbed car. I also do not have all the air box stuff on my car as well and it may interfear with the length of the filter.
    http://www1.snapfish.com/slideshow/A...70/t_=85267970
    The blue is the Honda filter of course the middle is the Puralator and the one on the right is a generic replacement for a Fram I had laying around.
    The only negative is this filter is about 6.35$ at Advanced Auto parts but it is right on the shelf.
  10. #35
    Mobile filters. Have good experience with them.
  11. #36
    just put one on my dx last night and changed the oil...man did it feel smooth.
    i use k&n gold filters part # hp-1004
  13. #38
  14. #39
    Ding Ding we have a winner. Puralator L30165 few inches taller might be a problem for people that still have there air box on the car. The gasket is larger but it seems to mate well to the filter housing. I'll be checking for leaks the next few days.
    And just for a laugher at myself. I changed out the trans fluid as well as as the power steering fluid. Putting the plug back in the oil pan I realized i got a split CV boot so I need to change out the shaft this week so much for new trans fluid it will have to get drained again
    Looks like Puralator L30165 is now not available as well. I'll start looking for suitable replacements here when I get a chance. I think the KN part number is still good for our car.
  15. #40
    DX User 89accordlxigentyers's Avatar
    Feb 2011
    89 Honda Accord Lx-i
    Urbana, Ohio
    Thumbs up Re: L24458 oil filter discontinued?
    It is deff worth spending the extra few bucks cause i was curious one day and had a old fram filter and a fresh used K&N filter off my 89 lxi. I used a saw zaw and cut them both in half to see which was better. Trust me the K&N has alot more filter space and catches all the sludge and nasty things we dont need in out motors. the fram barly had any filtration at all but the k&n has alot more flow... so i spend the 14 bucks for the K&N and use only Castrol GTX every 3000 miles. ***To be exact on the filter its a K&N 1004 filter***
  16. #41
    Purolator L30165 Classic Oil Filter : Amazon.com : Automotive
    Haven't seen any for sale in a while unless its on line like this one. Never did any research on any others. I never remember to until its oil change time.
    Just to add I use this filter because its bigger and holds more oil.
  17. #42
    Blue, I sure wouldn't be going out of my way to buy a Purolator filter. Worst oil pressure I ever had was a Purolator. The Wix from Napa or O'Reilly work great. No reason to re-invent the wheel here.
  18. #43
    PL24458 and the L24458 are $1.41 on rockauto.
  19. #44
    thats cheap. I got to Napa auto parts and use the Napa gold filter that is made by Wix i use the 1334 for my GSR engine. I also switched over to Valvoline Race oil 10-30. It has high zinc for lifters and keeps my motor running smooth at high rpms 7700rpm shifts because thats where my power drops off.
  1. Erebuni Kit Discontinued
    By HostileJava in forum Interior & Exterior Care
    Last Post: 05-08-2004, 10:27 AM
  2. Koni struts have been discontinued! You MUST ORDER NOW!
    By Jims 86LXI HB in forum Suspension/Wheels/Tires/Brakes
    Last Post: 07-10-2003, 02:07 PM
  3. Koni's being discontinued
    By stizle in forum Suspension/Wheels/Tires/Brakes
    Last Post: 06-26-2003, 11:10 AM
  4. aren't dc sports headers discontinued?
    By POS carb in forum Performance
    Last Post: 05-08-2003, 05:44 AM
