Results 1 to 10 of 10
Thread: Which would be better?
    LXi User oldschool3g's Avatar
    1989/Honda/Accord LXI HATCH
    somewhere in cali
    would it be better to rebuild my 132,000 mile A20A engine...or put in a new lower mile A20A? i wanna rebuid it with cam, port & polished and everything
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    Re: Which would be better?
    depends how much it would cost to rebuild... no gaurantee a lower milage engine will be better... I mean you can buy an abused low milage motor and end up worse off.
    You could try and get a spare motor, rebuild that and then swap it in when you're done, that way you don't have down time.
    LX User Listen2myBASS's Avatar
    1989 Honda Accord LX-i Coupe
    Born in Chicago moved to Plainfield...
    Quote Originally Posted by A20A1
    that is the best option that you can possibly think of!
    somewhere in cali
    well what would you do LISTENTOMYBASS?
    oh, did u think i was questioning him? i was applauding him, i mean it as a THAT is the best way to go, no other way would be better, do that, nothing else...sorry for miscommunication...
    somewhere in cali
    oh im sorry. well if thats the way to go...then thats how its going to be done....lol,....thanks guys
    i would say rebuild....i put one of thoes 40k miles into my car and the headgasket blew....put my car out of work for 4 weeks b4 i had the money to fix it.....plus your engine does not have alot of miles...you can get it ported and polished with a colt or delta cam on it.....i would first do a compresion test to fine out the condition that is on.
    somewhere in cali
    they did a compression test on it about a month ago and they said it was running fine at good compression...not sure exactly what it was but it was good.
    Accord of the Year - 2006
    guaynabo89's Avatar
    FL
    well just to get you some figures. Around 6-7 years ago I paid about 900 for complete rebuild of the bottom end with me supplying pistons, rings, rods, oil pump, seals. the only thing the shop got for me was the bearings. they bored out the block 30 over shotpeened, balanced and Miked( sp) all the rotating assembly. For a good head rebuild figure at least 500 for stock rebuild including valves guides and seals. at least arouudn 1000 for a half decent head job with complete rebuild and maybe a reground cam.
    Very minimum for a completely stock rebuild of the whole engine will be around 1300-1500 depending how much you can do yourself and what not. with performance goodies add about 4-500 for pistons aroun 650-700 for rods balancing and shotpeening is extra probably about 150 more and for the head with upgraded valvetrain, cam, port etc will be around a grand plus. depending on shops and what parts are available. So the performance rebuild will probably run you about 3000 give or take depending on shops parts etc.
    This was prices on machining a couple of years back so prices might have gone up since then.
    A20A1's Avatar
    Sep 2001
    Quote Originally Posted by Listen2myBASS
    I read it this way as well
    is that the BEST option that you can possibly think of!!!!!!!!!
    instead of this way
    but I reread it and found my error
