can i put some gsr injectors on my car?? kinda sounds like a noob question doesnt it? lol. im asking because the gsr is obiously a 1.8l will that affect anything if i put them on my car?? i can just give it like 5psi on the fpr![]()
Find out the rate they are good for, the voltage (probly the same I dont see why not) and if they'll fit. If thats all good, then I dont see why not. Some fabbing might be in order tghough
umm they are same size as whats in the car already... Why do you wanna change?
Pretty much all Honda injectors are the same flow rate which is 240cc. The only car that differs is the prelude with the h22 which bump up to 270cc. The plugs might not go into the injectors though as there were a couple if different injector plugs through the years. You can take a dremel t the injectors them selves to remove tabs and what not to make em fit your plugs though.( did this to my 4th gen)
Originally Posted by AccordEpicenter
mine arent working really well, the tips of them are all either broken in half or cracked. i already tried them to see if they would fit, and they do. just wanted to know if they were the same flow rate. thanx a lot guys.
hey gio i think the 4th gen accord injectors fit. also the 88-91 lude ones. also do the 4th gen map sensor mod.
if you are referring to those black caps on the end of the injector, just bust them all off, all they do is protect the pintle itself, that is all.
i have the map sensor, its stupid. if you have an afpr, then its pointless to do that. and i have the gsr injectors in the garage thats why i asked about those. ill see what happens.Originally Posted by MessyHonda
