Tailfin
Heh, thank you for the input, but I'm with the mechanics. Some additives...a few rather, are alright, but none of them are oil additives. And most of the ones that don't do harm don't do much good either. The only thing I'll really use something like that on is getting carbon out of the engine with GM top engine cleaner...or Seafoam, if you must. Lucas additives claim that they "coat" better...and if you turn their little gear demo in CarQuest, it looks like it does...but take a close look right where the bottom gear is as you're turning it, and you will see little air bubbles forming. At car engine speeds, gears accentuate this effect, not by magically coating the gears and such better, but it seems like that for a while because it gets air in the oil and it will foam all up, causing a much bigger mess.
I'm just not positive if the transmission is supposed to behave this way or not...but it doesn't seem like it. I do have concerns though...usually it shifts ok, but occassionally it's a little rough, and sometimes upon putting it in park, there's a split-second sound of gears chafing a bit.
