kw_da
Hi,
Thanks to all that replied. I was able to access the sensor from the bottom & get an adjustable wrench on the sensor & remove & replace ... so far, so good.
How do you get a discount from NAPA? They appear to have pretty good quality parts, but a little expensive (sometimes more than Majestic Honda). I try to buy Honda parts if I can since I don't want to deal with installing a part only to find out its bad (bad rebuilt master cylinder from Pep Boys). I also read in some other threads/forums that there are a bunch of cheap thermosensors that are DOA, or don't last long.
Of course, in the process of replacing the sensor, I found some oil leaking from around the oil pan, hopefully its just loose bolts (tightened them) and not something else (like the oil pump).
Regards,
David
