roodoo2
I dont neccessarily agree with that , the only way fuel goes into cyl when decellerating is if the throttle plates are open. Normally that condition does not exist with any make of car. /there may be a long term problem or adjustment going on with this car. these carbs do hold the throttle open with throttle controller when your not even touching the gas, but there are controls that moderate the opening until the reason is accomplished, A20A1 , what do you think , well he knows these carbs inside and backwards. Normal model cars do have what is called a dashpot that when you decel, you dont get the gas flow and backfiring . but Honda has its own unique way of dashpotting on the kelken carbs. Also there is a fuel cuttoff solenoid that cuts of fuel flow from float bowl at certin times.
Also three clutches in i200K miles could be kinda excessive, but its hard to say if oem parts were used , condition of flywheel etc. that would determine that kind of stuff. Myself when decelling from highway speed, just put it in fourth till it starts to jerka little and then put it in neutral until its tiime to go again, then use appropriate gear.p\ other things to check to adrdress your specific complaint leaving the carburator outta the conversation would be motor or transmission mounts, pressure plate-there bad about being reused on clutch jobs, and ignition timiing.
