Results 1 to 11 of 11
Thread: Heater issues
    Apr 2005
    88 Accord LX
    Alabama
    Heater issues
    OK,
    I looked for this in the forums, but couldnt find the exact answer I was searching for.
    The climate control fan in my 88 Accord will not blow, period. I have replaced both the #5 dash and #22 underhood fuse and the blower resistor. Any other ideas? I know next is probably the blower motor, but is there anyway I can check to see whether it is good or not? I have access to a multi-meter and a couple of electrical process engineers here at work, so having someone who knows their way around 12 volt shouldnt be an issue, I am just not sure what to check, or what readings I should receive during the checks.
    Gene
    Blkblurr's Avatar
    Jan 2004
    Dayton, Ohio
    Re: Heater issues
    Check to see if you have 12 volts going to the blower motor when it should be on. If you do then you need to replace the motor. If not, then it's some other problem.
    2ndGenGuy
    Guest
    Re: Heater issues
    If you pull the motor, just hook 12 volts to it directly and see if it turns on. That will tell you for sure if the motor is bad. Just jump it straight to a battery for a few seconds.
    Apr 2005
    88 Accord LX
    Alabama
    Re: Heater issues
    LOL didnt even think of trying that. I was kind of hoping to test it in the car, but I guess I will pull it out and see if I can figure out whats wrong with it.
    Gene
    Apr 2005
    88 Accord LX
    Alabama
    Re: Heater issues
    Ok, is there anything else it could possibly be? I got a good motor, but I still get nothing when I turn the fan switch on.
    Re: Heater issues
    the switch itself?
    Apr 2005
    88 Accord LX
    Alabama
    Re: Heater issues
    I didnt think the switches themselves went bad that often, but I guess I can try replacing it too. Does the actual switch come separately or will I need to buy a complete climate control assembly to replace it?
    Re: Heater issues
    well i highly doubt its a switch, but i can only think of either that or a broke wire somewere.... are ALL your fuses good though?
    Apr 2005
    88 Accord LX
    Alabama
    Re: Heater issues
    Yes,
    I replaced them anyways, and kept the old ones as spares just to make sure they were good. I gotta get this thing fixed, it was 30 degrees here this morning and my cajones almost froze off on the way to work
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    Re: Heater issues
    Sounds like you need to print out a wiring schematic of the whole system & troubleshoot the electical problem with a digital mulitimeter.
    Re: Heater issues
    well in the mean time get a nice heavy 30 amp toggle switch and wire straight off the battery with a nice 30 amp fuse holder and good heavy wire and your ready to rock and roll while you get it fixed right.
  1. Heater Hoses
    By SILENT in forum Classic Honda Community Chat
    Last Post: 12-16-2008, 07:12 PM
  2. heater issues won't turn on sometimes
    By Holy^ghost in forum 2geez Accords
    Last Post: 04-12-2007, 08:24 AM
  3. heater fan ??/
    By 3vg in forum 3geez Accords
    Last Post: 12-15-2003, 10:41 AM
  4. Air coming from heater not hot
    By Aarie$$oul in forum 3geez Accords
    Last Post: 12-10-2003, 02:50 PM
  5. efe heater?
    By accordlxi2.0 in forum 3geez Accords
    Last Post: 11-24-2003, 11:36 AM
