ok just changed the oil yesterday, oil pressure was fine after changing. castrol syntec blend 10w30 stp filter,which is the one identical to the bosch one. after driving I notice the oil pressure at idle is a bit low, on the way home it's really low at idle,fine at higher rpms. when I open the hood the motor is really hot like it's overheated. much hotter then usual. the gauge doesn't show overheated though. I've been having trouble with my water pump whining,was going to replace it tonight. does anyone think this could be caused by the water not circulating properly and throwing off the temp sender? the sender is all the way up in the intake and could be off. the engine is def hotter then the gauge says. I know when your engine really heats up it can cause lower oil presure. I was thinking the pump might be working at higher rpms only.
