hey everybody,
here's an update on what I've done on my car since I bought it in januari. that's a long time.. I know
Firstly I would like to appologize for 2 things:
1 for keeping you all in hte dark about my car and abusing this forum
2 for the crappy cell-phone pics.
I'm sorry you guys
hope you forgive me
well,
I bought my aerodeck januari 14th. And I loved it, still do. I drove it to my Honda dealer, where I also work every saterday, and eddie the mechanic changed the timing belt, and all the other belts..
this is what it looked like then
Isn't she a beaut? *sigh*
well, the previous owner didn't seel to think so, the complete idiot decided to do some diy to the car. appearently he didn't like the lock that opens the trunk. so he janked that out, filled the hole with a sock (I'm ashamed to say that i don't have a picture of that yet) and then put some plaster over it to fill the hole up evenly. then he painted the back end of the car, with a spraycan and scribbled "accord" on the back with a permanent marker. wich made it look like this
god I hat that guy..
well, that wasn't all, I have a sunroof that must have leaked because the idiot decided to seal it shut with windowsealent, the black mushi stuff that keeps your windshield in place (dunno what it's called) so I pried that open cleaned 2 of the 4 drainage holes, and the roof was fixed.
then I discovered a rusthole on the inside of my fender near the left rear wheel. It was a small hole, about 1 cm in diameter, so I figured that's an easy fix weld in a small patch and "bobs your uncle". I started to poke out the rust with a screwdriver and ended up with this
I cut 2 pieces out so I could weld proparly. but goddamn those were big holes..
you can see that the idiot had did some diy on the left rear fender too in the last pic. I took al look at that, from the hole I cut,it still looked ok no holes there, so I sprayed some tectyl (antirustspray, don't know if you guys know the brand) over it so it won't rot that fast..
I cut 2 pieces of sheet metal, and went "occ" on them, bending cutting welding shouting everything untill they fit. and I'm not a bodyshop man but they fit very well! if I do say so myself.
then I sprayed it with some black bubblespray and Sprayed some tectyl on the inside so rotting was stopped.. for now anyway.
