I wanted to check the timing on this 88 LX...and I have the service manual... It shows the light pointing towards the passenger side near where the distributor is...makes sense so far. It says to remove the rubber cover on the head inspection window or something...which I don't see. The distributor in the diagram is also pointing the opposite direction than on the car (like the part where you connect the vacuum advances is extending toward the front of the car, in the diagram it's toward the back). Anyhoo, long story short, I don't see any marks or anything to set the timing by...little help? :-P
