did you put gasket sealer on the corners of the valve cover gasket? thats where it leaks. where it goes from flat into the bearing caps. on the cyl head itself,then set the vave cover on the sealer. don't overtighten it or it will leak also. the hose that goes from the pan up the back side of the engine is for your pcv system. it goes into a liquid vapor seperator on the back of the block,then the vapors are pulled up through the pcv valve into the intake. the dizzy seal is an o ring, there seem to be two different seals,because every time i order one,honda gives me the wrong one. they are cheap,order both. then you've got it. were you talking about your water pump leaking? if it is,run a bead of sealer in the o ring groove,put the o ring in it,smear some more on top of the ring,then stick it in place. it won't leak. sometimes gaskets don't like to seal well on old engines. good time to paint some of your engine parts too while they are out. https://www.3geez.com/forum/showthread.php?t=55344Originally Posted by Jasonf860
