I had a heck of a time getting the timing belt on the proper way. the car would seem to run ok, but I would have like 20 degrees of static advance lol, so i would be running like 32 degrees with the diaphram pulling more!!!
the trick that I found is this:
- get the flywheel to tdc and and the cam gear to tdc. u can leave them alone for a bit.
- make sure tensioner is loose
- pull the 'front' part of the belt onto the gear, you can probably only get it half way on like this.
- pull up as hard as you can and slide the back half of the belt on, using the tensioner to pull more slack out of the belt so you can slip it on.
only turn the cam gear 3 teeth
- tighten the tensioner
- manually turn it over to make sure they are still in sync
-try it out.
the part i always screwed up was turning the engine over a couple times before i tightened the tensioner. i am not sure why this seems to be so critical. but it seems to make a big difference.
